Some of you have been impatiently waiting to test our 3G service. Starting 25/03/2010 (with 95% certainty, you never know), all Mobile Vikings will be able to use the 3G network. This blog post explains how the introduction will happen.
You do not need to do anything to switch to 3G. Most mobile phones will detect the 3G signal where it is available. If your phone is on “automatic”, it will choose 3G where appropriate and switch to EDGE when needed. In some locations there is a 3G signal, but your phone does not switch to it. It is not advised to configure your phone to manually force a 3G connection in these locations. The connection will be made, but no data will be transported over the connection. Your phone will indicate it is connected, but your web browser will not work. We are writing this explanation in the hope to avoid unnecessary helpdesk calls. If you see people complaining online about the above situation, you can always reply with a link back to this blog post.
If you want to test the connection speed, you will notice it will not exceed 500 Kbps. This is not a limitation of the technology. During the first phase, all connections are restricted to 500Kbps to gradually increase the load on the network. We don’t know yet when this capping will be removed.
As most of you will know, 3G coverage is not available everywhere. We are using the 3G network of KPN Belgium (Base), which is under continuous expansion. Where there is no 3G coverage yet, you can fall back on the reliable EDGE network. For more information regarding network coverage and expansion we refer to the communication of Base.
We hope this information will help us make a nice transition to 3G. We are convinced that the 3G network of Base will soon be up to par. The 2G network is already better than the network of Mobistar and Proximus, as reported by this independent report on network quality: http://mobilevikings.com/media/download ... 09_sam.pdf
Mobile Vikings 3G - 25 Maart
ChelloExtremer
- Bedankt: 30 keer
Quote van Mobile Vikings:
gregmans
- Bedankt: 3 keer
En inderdaad, 3G is er!
Met het binnenrijden in Antwerpen met de trein al van voor Berchem station 3g ontvangst. Deze viel echter terug weg
in de buurt van het Centraal Station.
Maar voor de rest wel perfect 3G ontvangst @ 0,47/0,47 Mbps.
- krisken
- Bedankt: 1035 keer
www.3gcoverage.net
In Merelbeke (Gent) volop 3G ontvangst, vorige week in Knokke ook al!
texarcanaa
- Bedankt: 7 keer
In Brussel (Evere) ook volop 3G ontvangst
- krisken
flt, van waar in merelbeke ben jij dan?
Mobile Viking
- Bedankt: 7 keer
Hier in de regio Brugge-Kust nog nergens 3G kunnen gebruiken.
- krisken
Aan het Casino te Knokke heb ik het kunnen gebruiken.
q-tec
- Bedankt: 103 keer
hmm in deinze nog niks? ik zit op edge en een kennis zit op 3g (base) en we stonden naast elkaarflt schreef:Ben van Deinze maar passeer nogal veel langs Merelbeke
Speedtest is gedaan op de N60 in Zwijnaarde
(markt)
flt
- Bedankt: 3 keer
Nopeq-tec schreef:hmm in deinze nog niks? ik zit op edge en een kennis zit op 3g (base) en we stonden naast elkaarflt schreef:Ben van Deinze maar passeer nogal veel langs Merelbeke
(markt)
Niet dat ik het verwacht had in deze wereldstad (
