One 13 year old boy , named Gentill Abdulla, has said that he has a time machine plan that is going to work. I have personally met him and he is an extremely bright boy. Gentill says that his ingenious plans can allow time travel to be possible. He told me " I have done a lot of research on the areas of black holes, time travel, wormholes, magnetism, light, and most importantly gravity. I have devised an experiment that if done correctly could allow time travel . Here is the theory. If you had magnets in front of each other and had one beam of blue light that had been traveling for thousands of years and put that in the middle of these two magnets then turned on lasers on each magnet , and the side they are pointing makes the magnets face each other, and when the magnets are heated have eight smaller magnets on each magnet and make those magnets so that they would repel the big magnet.
Then move all these magnets toward the plastic magnet so it will compress it on all sides so it will become smaller than it's Schwarzschild radius. After this is done the magnets both should become black holes. Since they are facing each other their gravities will act and join these black holes together. There will still be a singularity but it will be magnetic. Now you make a device, that I have also made, that will split the singularity into a ring.This device that will make a hole in the singularity. Since the string is no longer there the magnets will expand enough to make the singularity into ta ring. You will know if it works because you will be able to see the other side of the hole from the entrance. Since the beam of light is old and the light beam is what is creating the effect you will be able to go back to when that beam of light was first made.So through this it will make a traversable wormhole. The negative energy really won't be negative energy because since the smaller magnets are repelling the singularity it will push it outward in the opposite way or just rotate the 2 magnets from the begining so you don't have that problem.Contact me at [email protected]" he has also told me that he has all the paperwork and schematics with him at all times. Gentill says that he is working on a new Grand unification theory and perpetual motion machine.
Bron: http://www.ireport.com/docs/DOC-367891
13-jarige heeft plannen van een tijdmachine die werkt
- Erelid
- Bedankt: 386 keer
Gesproken van paradoxen.
1) Hadden we het nu wel al niet gemerkt had hij terug in de tijd geweest?
2) Hadden we het überhaupt iets gemerkt?
3) Zouden we wel iets mógen merken?
4) volgens wetenschappers bestaan er honderden miljoenen parallelle universum (universa?), gelijk aan de honderden miljoenen keuzes die mensen kunnen maken. Had hij toch iets kunnen veranderen aan vroeger, zouden we het niet kunnen of mogen weten. Want op dat moment creëert hij gewoon een ander universum.
5) hij heeft het niet over mensen of objecten transporteren in tijd. Tot nu toe is tijdreizen onmogelijk.
Tenzij ze de temporal prime directive gaan schenden.
- Dafke
- Uitgedeelde bedankjes: 181 keer
- Bedankt: 142 keer
btw, draai het of keer het hoe je wil, een perpetual motion machine is tot op heden eigenlijk volledig uitgesloten.
We hebben gewoon de kennis niet, het inzicht en de middelen.
En dat 13-jarig neuzeke heeft het gevonden?
Dus hij vindt EN tijdreizen uit EN Perp Mobile?
prima zo!
prima zo!
- Bedankt: 1985 keer
The plastic magnetAnD schreef:toward the plastic magnet
- Bedankt: 56 keer
r2504 schreef:The plastic magnetAnD schreef:toward the plastic magnet
Tja, dat is alvast niet verzonnen.
http://en.wikipedia.org/wiki/Plastic_magnet
Mmm... en het heeft zelfs nog iets te maken met een "blue-laser" ook
Ik heb dit al eens gezien op tv ! Stargate SG-1 ..http://images.google.be/images?hl=nl&sa ... q=&start=0AnD schreef:
singularity
a device, that will split the singularity into a ring.
professioneelAnD schreef:
[email protected]
Alleen is dat theoretisch onmogelijk. Spijtig. Tenzij hij met zijn unificatie theorie dat weerlegtAnD schreef:
Type gewoon eens 419 in Google.
En alles wordt u duidelijk.
Of het is een emo kid die aandacht wil. Of een reclame bureau
Aangezien hij ook op twitter zit: http://twitter.com/GentillAbdulla
Zal het wel reclame zijn.
Op 2 februari schreef hij dit: To everyone that is following me! MY time machine should be FINISHED by SATURDAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dus we zijn zaterdag al gepasseerd, en geen tijdmachine. Nuja, als hij er ooit een heeft, kan hij gewoon terugkeren naar zaterdag 2 februari en zijn plannen aan zichzelf tonen zodat het wel klaar is tegen de zaterdag na 2 feb hé
Laten we het maar op een emo kid houden...What got you interested in time machines?
When I first heard about time travel in the TV series Dragonball Z.
- Uitgedeelde bedankjes: 487 keer
- Bedankt: 556 keer
En zelfs dat is niet meer nodig als hij er ooit in slaagt
