Enkele maanden geleden had scarlet het AS 3304 met c&w + globalcrossing als transit en bnix peering.
Maar nu heel het netwerk (dus ook scarlet dc vilvoorde) overgenomen is door de nmbs...en scarlet nu het belgacom netwerk gebruikt...
Is er iemand die weet wat het huidige AS is van dit netwerk + welke transits/peerings belgacom heeft?
Scarlet netwerk
- krisken
- Bedankt: 1035 keer
- FunkStar
- Bedankt: 95 keer
-> http://tinyurl.com/yccuthbBelgacom ICS' IP Transit is today’s internet solution for dynamic operators, delivering the most extensive, reliable and competitive connectivity over 4 continents using high performance IP/MPLS routing platforms.
Belgacom ICS' IP Transit delivers full internet connectivity via more than 600 peerings at 10 exchange points across Europe, including LINX, AMSIX, SFINX, BNIX and DECIX and selected Tier-1 providers with quality global connectivity.
Customers may connect to Belgacom ICS' IP/MPLS backbone over more than 70 points of presence in 42 cities in Europe, Asia, and North America or alternatively may leverage international private line circuits on submarine cables as well as satellite links.
- krisken
peerings hebben we nu al...maar nog altijd ni de transits
- FunkStar
- Bedankt: 95 keer
Moe zeggen die vind ik nie direct, vind veel informatie over MMS-SMS transit maar welke precies geen idee.krisken schreef:peerings hebben we nu al...maar nog altijd ni de transits
MMS Transit, the Ultimate Answer to Mobile Operators’ MMS Coverage Needs
Belgacom ICS’ MMS Transit is the ultimate answer to mobile operators’ and service providers’ needs for a multilateral solution for international MMS delivery which can perfectly co-exist with their current bilateral relations. With a single connection to Belgacom ICS’ MMS Transit platform, mobile operators and service providers gain access to 250+ interworking destinations with 2-way message exchanges in adherence to GSMA recommendations. With the launch of the optional ‘MMS Virtual Delivery’ feature, Belgacom ICS moreover offers worldwide MMS coverage.
Anyway voor wat staat AS?SMS Transit, the Perfect Answer to Instantly Extend Your International SMS Coverage
No longer confined to technology, SMS has become a truly global communication experience across wireline and wireless networks. Belgacom ICS' SMS Transit is the ultimate answer to gain a competitive advantage in a cost-effective manner. SMS Transit offers unrivalled international coverage to 750+ destinations across all wireless standards with mobile number portability support, delivery receipt integrity and detailed reporting information on usage.
SMS Transit is a carrier-grade SMS interworking gateway capable of recording high delivery success ratios thanks to routing decisions based on an accurate worldwide numbering plan and high-quality connections to one of the world's largest SMS hubbing communities. For mobile operators, the SMS Transit Service complements the established set of bilateral SMS traffic exchanges (AA.19) through a single interconnection to reach an extensive set of destinations, while preserving a consolidated procedure of accounting, charging, invoicing and settlement in adherence to GSMA recommendations.
- krisken
AS = Autonomous system
Bvb AS van scarlet is/was 3340 dacht ik
http://en.wikipedia.org/wiki/Autonomous ... nternet%29
Ik vraag me af krijg je nu een evenwaardig product als belgacom.
Daarme bedoel ik als je met belgacom 11 van de 12 haalt zal je die halen met scartlet ook halen ?
Want hun snelheden lieten veelal de wensen over.
Teveel mensen voor te weinig capaciteit !! Heb ik zalf mogen ondervinden
nokia e71 smile 110 + mobile internet + agent
nokia 6120C belgacom happy time one
nokia 3500 TMF
nokia 3120 classic base mania
toshiba p300-18M + vista ultimate + office 2007
toshiba Qosmio X300-14F VDSL2 internet generation + happy time on + belgacom tv
nokia 3500 TMF
- Bedankt: 222 keer
Wel Scarlet is toch wel een stuk trager als ik vergelijk. Ik heb een Scarlet no limit (wel ADSL2+) en een BGC Internet generation (VDSL2) die beiden op 12Mbit down syncen en waar ik met BGC bij de speedtest toch steeds 11,5Mbit haal varieert dit bij Scarlet tussen 6 a 9Mbit.
Internet: EDPNet VDSL
Telefonie: OVH
GSM: Proximus
Telefonie: OVH
GSM: Proximus
- FunkStar
- Bedankt: 95 keer
Hoe kan je nu een adsl+ lijn met een VDSL2 vergelijken.VOiD schreef:Wel Scarlet is toch wel een stuk trager als ik vergelijk. Ik heb een Scarlet no limit (wel ADSL2+) en een BGC Internet generation (VDSL2) die beiden op 12Mbit down syncen en waar ik met BGC bij de speedtest toch steeds 11,5Mbit haal varieert dit bij Scarlet tussen 6 a 9Mbit.
Dat is net lijk appelen met peren vergelijken...
tussen 6&9mbit voor adsl+ is heel mooi.
- FunkStar
- Bedankt: 95 keer
Bij VDSL2 is vanaf 1.6 km de prestatie gelijk aan die van ADSL2+
maar normaal gezien staat de ROP < km
Dit zou genoeg moeten zeggen.
Ik kan verkeerd zijn maar dan zou ik toch wel even wat argumenten willen zien ^^
Rekening houdend kwaliteit koperkabel, afstand, aansluiting in huis, etc...
- Bedankt: 300 keer
De achterliggende technologie is anders:VOiD schreef:12Mbit met 12Mbit vergelijken lijkt met toch niet appelen met peren vergelijken of wel ?
12Mbit via ADSL2+ is niet hetzelfde als 12Mbit via VDSL2
Dus kun je beide niet zomaar vergelijken, dus geen appels met peren vergelijken
- Bedankt: 222 keer
Funkstar,
Ben je iets met deze gegevens ?
VDSL2 verbinding:
Downstream Training Margin : 33.2 dB
Downstream line rate : 20048 kbps
Upstream line rate : 2032 kbps
TX total power : -33.4 dbm
Downstream delay : 7.6 ms
Upstream delay : 3.5 ms
ADSL2+ verbinding:
Maximale lijnsnelheid: 24880 kbps (downstream) / 1305 kbps (upstream)
Ruismarge: 22.5 dB (downstream) / 31.3 dB (upstream)
Lijndemping: 9.4 dB (downstream) / 1.3 dB (upstream)
Uitgangsvermogen: 18.4 dBm (downstream) / 12.2 dBm (upstream)
Ik ben geen specialist op niveau van DSL protocols maar afgaande op bovenstaande gegevens lijkt het mij toch dat de ADSL2+ verbinding qua download beter is dan de VDSL2.
Met vriendelijke groeten,
VOiD
VDSL2 verbinding:
ADSL2+ verbinding:
VOiD
Telefonie: OVH
GSM: Proximus
Telefonie: OVH
GSM: Proximus
dat is zo meteen mijn vraag niet !
Er is namelijk een verschil tussen belgacom adsl en scarlet adsl
is er eenverschil tussen vdsl belgacom en vdsl scarlet
nu scarlet overgenomen is
nokia 3500 TMF
nokia 3500 TMF
welk dan?proximusboy schreef:dat is zo meteen mijn vraag niet !
Mss tijdelijk omdat nog niet iedereen is overgezet.
evenveel als tussen scarlet en dxadsl (dxadsl is reseller)is er eenverschil tussen vdsl belgacom en vdsl scarlet
snelheid belgacom adsl en scarlet adsl is/was er een verschil
nokia 3500 TMF
nokia 3500 TMF
- Goztow
- Bedankt: 1450 keer
In theorie is er geen enkel verschil tussen Scarlet en BGC VDSL2. Echter: indien Scarlet te weinig capaciteit inkoopt, zal de werkelijke snelheid verschillend zijn bij Scarlet in piekuren! En dat is nu de vraag, natuurlijk.
voila dat bedoel ik , indien een volwaardige dochteronderneming zou dit geen probleem zijn.
Vraag is moeten ze nog inkopen of mogen ze onbeperkt gebruik maken omdat het toch van belgacom is
nokia 3500 TMF
nokia 3500 TMF
- Erelid
- Bedankt: 386 keer
Men hoopte bij de overname dat die capaciteitsproblemen opgelost gingen geraken. Nieuwe management, nieuwe ingenieurs, of tenminste volk dat hun werk beter doet.
je kan blijkbaar enkel adsl2+ hebben
nokia 3500 TMF
nokia 3500 TMF
- Erelid
- Bedankt: 386 keer
Die kerel met wie gij sprak is ronduit verkeerd.proximusboy schreef:je kan blijkbaar enkel adsl2+ hebben
ok
want ik zei hem dat belgacom daat vdsl aanbood moest telefoonnr geven en zei ja maar wij geven aan onze klanten max adsl2+
dusja als de technische mensen het al nie weten
nokia 3500 TMF
nokia 3500 TMF
