![Afbeelding](http://userbase.be/forum/images/phone.png)
Sat, 2000-01-01 01:07:16 - Initialize LCP.
Sat, 2000-01-01 01:07:16 - Plugin pppoa loaded.
Sat, 2000-01-01 01:07:16 - PPPoA Plugin Initialized
Sat, 2000-01-01 01:07:16 - Plugin pppoa called.
Sat, 2000-01-01 01:07:16 - PPPoATM setdevname_pppoatm - SUCCESS
Sat, 2000-01-01 01:07:16 - Options file - /etc/ppp/options.8.35.
Sat, 2000-01-01 01:07:16 - pppd 2.4.1 started by root, uid 0
Sat, 2000-01-01 01:07:16 - setting line discipline hook
Sat, 2000-01-01 01:07:16 - connect_pppoatm_ses...Enter
Sat, 2000-01-01 01:07:16 - connect_pppoatm_ses: socket created fd - 0x6.
Sat, 2000-01-01 01:07:16 - connect_pppoatm_ses: setsockopt called.
Sat, 2000-01-01 01:07:16 - connect_pppoatm_ses: connect successful.
Sat, 2000-01-01 01:07:16 - Calling line discipline hook
Sat, 2000-01-01 01:07:16 - Setting pppoatm line discipline.
Sat, 2000-01-01 01:07:16 - LLC encaps.
Sat, 2000-01-01 01:07:16 - using channel 4
Sat, 2000-01-01 01:07:16 - Using interface ppp0
Sat, 2000-01-01 01:07:16 - Connect: ppp0 <-->
Sat, 2000-01-01 01:07:16 - LCP is allowed to come up.
Sat, 2000-01-01 01:07:56 - lcp echos pending >= lcp_echo_fails!
Sat, 2000-01-01 01:07:56 - No response to 3 echo-requests
Sat, 2000-01-01 01:07:56 - Serial link appears to be disconnected.
Sat, 2000-01-01 01:07:56 - LCP down.
Sat, 2000-01-01 01:08:02 - Connection terminated.
Sat, 2000-01-01 01:08:02 - Exit.
--- System Information ---
Vendor: Linksys
ModelName: WAG325N
Firmware Version: A1.00.12 , 2008-01-25
Boot Version: 1.0.37-5.4
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB022g.d20e
DSL VPI/VCI: 8/35
DSL Status: ShowtimeRetrain Reason: 0
DSL Mode: ADSL2+
DSL Channel: FAST
DSL Upstream Rate: 509 Kbps
DSL Downstream Rate: 9020 Kbps
Down up
DSL Noise Margin: 21.2 dB 28.5 dB
DSL Attenuation: 26.5 dB 10.9 dB
DSL Transmit Power: 19.1 dBm 11.9 dBm
