fritzbox update 29.04.76
silencer
Bedankt: 103 keer
Changes in 29.04.76:
- DSL: improved DSL-driver for better interoperability
- DSL: possibility to send feedback about the DSL-line directly from within the FRITZ!Box
- Internet: Child protection improved
- Internet: improved compatibility for SetTopBoxes (RTSP)
- System: Improved security for the web-interface
- System: Improved UPnP-communication
- Telephony: added supported Codecs (clearmode)
- Telephony: SIP-proxy added (IP-telephones can now directly connect to the FRITZ!Box)
- Telephony: block incoming anonymous calls depending on the number that is beeing called
- Telephony: multiple fax numbers can forward the received faxes to different email-adresses
- USB: Spindown for USB harddrives to reduce energy consumption
Important: This firmware is only intended for use with FRITZ!Box Fon WLAN 7170 (Annex B).
Product: : FRITZ!Box Fon WLAN 7170
Version : 29.04.76
Build : 09.08.05
Language : English
Annex : B
English of de gepatchste duitse versie (language patch).
Terug naar “VoIP”
