Nieuwe gebruiker maar kan niet inloggen bij dxadsl :-(
Stekke28
Ik ben juist van scarlet veranderd naar dxadsl business abonoment juist voor fix ip
Ik heb mijn modem als volgt ingesteld
pppoa
vpi 8
vci35
ubr
LLC
modem is Linksys WAG160N Ultra RangePlus Router/ADSL2+ Modem, 300Mbps Annex A
Ik heb ook een optie ads multimodus maar ik weet wat kiezen daar
-Multimodus
T1,413
G.dmt
G.lite
Adsl2
adsl2+
adsl2 l
adsl2 m
adsl2+ m
Sat, 2000-01-01 01:25:50 - Terminating on signal 15.
Sat, 2000-01-01 01:25:50 - LCP down.
Sat, 2000-01-01 01:25:51 - Terminating on signal 15.
Sat, 2000-01-01 01:25:51 - LCP down.
Sat, 2000-01-01 01:25:53 - Terminating on signal 15.
Sat, 2000-01-01 01:25:53 - LCP down.
Sat, 2000-01-01 01:25:56 - Terminating on signal 15.
Sat, 2000-01-01 01:25:56 - LCP down.
Sat, 2000-01-01 01:25:56 - Connection terminated.
Sat, 2000-01-01 01:25:56 - Exit.
Sat, 2000-01-01 01:25:58 - Initialize LCP.
Sat, 2000-01-01 01:25:58 - Plugin pppoa loaded.
Sat, 2000-01-01 01:25:58 - PPPoA Plugin Initialized
Sat, 2000-01-01 01:25:58 - Plugin pppoa called.
Sat, 2000-01-01 01:25:58 - PPPoATM setdevname_pppoatm - SUCCESS
Sat, 2000-01-01 01:25:58 - Options file - /etc/ppp/options.8.35.
Sat, 2000-01-01 01:25:58 - pppd 2.4.1 started by root, uid 0
Sat, 2000-01-01 01:25:58 - setting line discipline hook
Sat, 2000-01-01 01:25:58 - connect_pppoatm_ses...Enter
Sat, 2000-01-01 01:25:58 - connect_pppoatm_ses: socket created fd - 0x6.
Sat, 2000-01-01 01:25:58 - connect_pppoatm_ses: setsockopt called.
Sat, 2000-01-01 01:25:58 - connect_pppoatm_ses: connect successful.
Sat, 2000-01-01 01:25:58 - Calling line discipline hook
Sat, 2000-01-01 01:25:58 - Setting pppoatm line discipline.
Sat, 2000-01-01 01:25:58 - LLC encaps.
Sat, 2000-01-01 01:25:58 - using channel 21
Sat, 2000-01-01 01:25:58 - Using interface ppp0
Sat, 2000-01-01 01:25:58 - Connect: ppp0 <-->
Sat, 2000-01-01 01:25:58 - LCP is allowed to come up.
Sat, 2000-01-01 01:26:28 - LCP: timeout sending Config-Requests
Sat, 2000-01-01 01:26:28 - Connection terminated.
Sat, 2000-01-01 01:26:28 - Exit.
Sat, 2000-01-01 01:26:49 - Adsl is connected
Sat, 2000-01-01 01:26:49 - Initialize LCP.
Sat, 2000-01-01 01:26:49 - Plugin pppoa loaded.
Sat, 2000-01-01 01:26:49 - PPPoA Plugin Initialized
Sat, 2000-01-01 01:26:49 - Plugin pppoa called.
Sat, 2000-01-01 01:26:49 - PPPoATM setdevname_pppoatm - SUCCESS
Sat, 2000-01-01 01:26:49 - Options file - /etc/ppp/options.8.35.
Sat, 2000-01-01 01:26:49 - pppd 2.4.1 started by root, uid 0
johcla
Bedankt: 156 keer
Op het 1e zicht zie ik ook niks verkeerd.
Ik heb dxadsl en heb de eerste keer ook moeten prutsen. Uiteindelijk bleek dat de userid ook @dxadsl.be moet bevatten. Mss ook eens nakijken?
Mijn modem is een Fritzbox router, daar heb ik die Multimode instelling niet.
Ik heb nog wel een BASE Freedom adsl abb met een linksys router, daar staat het gewoon op Multimode.
Stekke28
Ik zal het zeker proberen maar het is raar dat er .be bij moet en ik heb een login dxadslfix achteraan op mijn brief dxadsl
liger
bij mij staat het zo ingesteld
login: spbxxx@dxadsl
pass: xxxx
johcla
Bedankt: 156 keer
Net even dubbel gecheckt.
Bij mij staat er [email protected]
Limburg
Bedankt: 4 keer
Stekke28:
Bij mij op m'n speedtouch
Connection Settings
PVC Info (VPI.VCI): 8.35
Type: PPPoA
PPP Settings
Username: spbxxxxx@dxadslfix
Password: ********
Connection Mode: Always-On
In je log zie ik je niet aanloggen op de radius server, ik heb het gevoel dat er in het dxadslnetwerk een routing nog niet goed staat.
Helpdesk bellen en probleem voorleggen.
Laatst gewijzigd door Limburg 08 jun 2009, 17:29, in totaal 1 gewijzigd.
KK
Ik gebruik PPPoE bij dxADSL en mijn login naam in de modem is van het formaat 'spb12345@dxadsl', alles in kleine letters en geen .be erachter.
liger
heb je eigenlijk helpdesk al gecontacteerd?
strangerke
Een tijd terug ook problemen gehad met de verbinding .
Helpdesk gebeld en ik moest login ; spb12345@fulladsl gebruiken , sindsdien staat hij daar nog op , en alles werkt perfect :-D
