Zeer rare (lijn)waarden ?
Hebt u vragen of opmerkingen over de speedtest? Deze kan u hier plaatsen
DoubleD
Ik heb na een tijd altijd zeer rare waarden in mijn copperjet 1616-p2 modem.
Driver Version    	1.65
API Version 	GS_API_593
Firmware Version 	E.67.5.12
Dsp Version 	Turbo v1.0 A0 (0x40)
Connected 	true
Operational Mode 	G.Dmt
State 	Showtime
Watchdog 	0x00000053
Operation Progress 	0x000000ad
Last Failed 	0x00000000
Tx Bit Rate 	32000
Rx Bit Rate 	0
Rx Attn DR 	0
Code Type Status 	ADSL2A
Tx Cell Rate 	75
Rx Cell Rate 	0
Phy Tx Cell Count 	83340
Phy Rx Cell Count 	1562488
Phy Cell Drop Count 	24006
Overall Failure 	0
Max Interleave Depth 	64
INP Up 	0.0
INP Down 	0.0
PM Mode
PM Status 	L0
SHalf
Cabinet Mode
Auto SRA
Auto SRA Max Time CRC
Auto SRA Max Time FEC
Auto SRA Up Shift Period
Auto SRA Dn Shift Period
Data Boost 	Disable
Local ITU Country Code 	0x0000b5ff
Local SEF 	0
Local End LOS 	0
Local SNR Margin 	29.5 dB
Local Line Attn 	0.0 dB
Raw Attn 	43.0 dB
Local Tx Power 	10.9 dB
Local Fast Channel Rx Rate 	0
Local Fast Channel Tx Rate 	0
Local Fast Channel FEC 	0
Local Fast Channel CRC 	40
Local Fast Channel HEC 	17
Local Fast Channel NCD 	0
Local Fast Channel OCD 	0
Local Interleaved Channel Rx Rate 	0
Local Interleaved Channel Tx Rate 	32000
Local Interleaved Channel FEC 	0
Local Interleaved Channel CRC 	0
Local Interleaved Channel HEC 	0
Local Interleaved Channel NCD 	0
Local Interleaved Channel OCD 	53839
Remote Tx Power 	-185.7 dB
Remote SEF 	0
Remote LOS 	0
Remote Line Attn 	0.0 dB
Remote SNR Margin 	0 dB
Remote Fast Channel FEC 	0
Remote Fast Channel CRC 	0
Remote Fast Channel HEC 	0
Remote Fast Channel NCD 	0
Remote Interleaved Channel FEC 	0
Remote Interleaved Channel CRC 	0
Remote Interleaved Channel HEC 	0
Remote Interleaved Channel NCD 	0
Local Mgmt FEC0 	0
Local Mgmt CRC0 	0
Local Mgmt FEC Errored Sec 	0
Local Mgmt Errored Sec 	0
Local Mgmt Severely Errored Sec 	0
Local Mgmt LOS Errored Sec 	0
Local Mgmt Unavail Errored Sec 	0
Local Mgmt HEC0 	0
Remote Mgmt FEC0 	0
Remote Mgmt CRC0 	0
Remote Mgmt FEC Errored Sec 	0
Remote Mgmt Errored Sec 	0
Remote Mgmt Severely Errored Sec 	0
Remote Mgmt LOS Errored Sec 	0
Remote Mgmt Unavail Errored Sec 	0
Remote Mgmt HEC0 	0
Local TPSTC Cell0 	0
Local TPSTC Cell0 Upper Layer 	0
Local TPSTC Bit Error 	0
Remote TPSTC Cell0 	0
Remote TPSTC Cell0 Upper Layer 	0
Remote TPSTC Bit Error 	0
PSD Mask
Host Control 	Enable
Auto Start
Failsafe 	false
Whip
Whip Active 	Inactive
Status Fail Count 	0
Action
Profile
Profile Status 	MAIN
Standard
Ec Fdm Mode
Max Bits Per Bin
Tx Start Bin
Tx End Bin
Rx Start Bin
Rx End Bin
Rx Auto Bin Adjust
Tx Attenuation
Bit Swap
Bit Swap Up
NTR Mode 	Disable
Code Type
Max Down Rate
Physical Port 	0
Retrain
Detect Noise
Capability
Coding Gain
Cut Back
Framer Type
Fast Retrain
Dying Gasp 	Disable
Defaults
Happy Mode
Activate Line
Reset Defaults
Port Snmp If Index 	1
Port Snmp If Type 	37
WTH is dit ? :P
DoubleD
niemand die dit weet? Ö
Terug naar “Speedtest”
