Ik zal deze topic maar beginnen met te zeggen dat ik door een "domme" handeling de modem vermoedelijk verneukt heb.
Het gaat om een Alcatel Speedtouch Home modem (PSTN) die een hack naar pro ondergaan heeft in het verleden. Welnu, telnetten naar de modem (10.0.0.138) lukt niet meer alsook naar de webinterface browsen en tevens werkt ook de reset-knop aan de achterkant niet. Ik heb al gezocht naar een oplossing en die deels gevonden op onderstaande link:
http://www.petri.co.il/forums/showthread.php?t=698
I had the same problem on 2 such units. The reset button on the "ST Home" model appears to do nothing. All instructions I have seen have all said that when the reset button is pressed, the "Power" LED should change to amber to signify that it is actually resetting back to default settings.
I tried for days to get these modems to reset (as it appeared that someone had set passwords on them, and I couldn't get into them to configure).
Eventually, I removed the "mainboard" from one and checked the functionality of the reset switch. The push button switch appears to function correctly (based on the multi-meter readings). I still could not get it to reset to default (and get rid of the password request).
Keep in mind thet the "mainboard" is likely to be the same for both the Home and Pro, and I started to think about the "default reset" procedure for the "Pro" units. The only apparent difference, is that the Pro models have the set of 4 dip-switches, and the Home models have just the one push-button reset switch. The mainboard in the "Home" model still has the 8 connectors (or rather the solder points for them) on the board for the 4 dip-switches and the 9 connectors for the serial console port.
By looking at the layout of the dip-switches and the serial console port for the Pro model, you can easily see which "pair" of solder points on the board need to be bridged to perform the "Pro version reset". This procedure did reset the defaults (and maintained the "Pro upgrade").
This method is not for the "beginners", but it did work on my 2 modems. You will need to dismantle the modem by removing (in my case, at least) 4 "torx" screws that were hiding under the barcodeed serial number sticker under the modem. You don't really need to remove the mainboard from the lower casing, as you can access the connections from above.
I hope this helps a few people out, as I have seen this issue on a few boards before.
I think that, as a part of the upgrade process, the reset function is changed to the "Pro" and therefore disables the push button reset option. I don't have acces to another of these modems at the moment, but the next time I have one, I'll upgrade it and test the reset, and then revert to "Home" and see if the reset option is re-instated.
Good luck.
Smile
Scorpiosez
Nu was mijn vraag, omdat ik niet beschik over een echte pro-versie, welke van de soldeerpunten op de printplaat ik dien te "shorten" of te bruggen om zo een reset teweeg te kunnen brengen ?
Ik heb een paar foto's genomen van de printplaat:
http://users.edpnet.be/speedyg/Alcatel_ ... Home_1.jpg
http://users.edpnet.be/speedyg/Alcatel_ ... Home_2.jpg
http://users.edpnet.be/speedyg/Alcatel_ ... Home_3.jpg
Kan iemand mij hier bij helpen (door bijvoorbeeld op 1 van de foto's aan te duiden welke soldeerpunten ik dien te bruggen) ?
						Alcatel Speedtouch Home (hacked naar pro) probleem
				vasonline
- Bedankt: 18 keer
[quote="Speedygekko"]Ik zal deze topic maar beginnen met te zeggen dat ik door een "domme" handeling de modem vermoedelijk verneukt heb.
Heb je de ping of life a geprobeerd?
http://www.petri.co.il/set_the_ethernet ... me_pro.htm
'k heb er zo al eentje kunnen redden.
Groetjes,
Steven
Groetjes,
Steven
Het probleem is dat hij niet uitlegt welke dip-switch het precies is... dus je zal eerst de documentatie moeten zoeken van de Pro versie.  De soldeerpunten waarover hij het heeft zijn vermoedelijk deze onder de blauwe reset knop (waarvan er dus op je foto twee links, en twee rechts zichtbaar zijn... en dus nog vier verborgen zitten onder de blauwe reset knop).
				Speedygekko
- Starter
Ping-of-life en alle andere methodes (ping-to-defaults, switch-to-defaults en browse-to-defaults) uit de manual reeds geprobeerd, zonder effect helaas...vasonline schreef:Speedygekko schreef:Ik zal deze topic maar beginnen met te zeggen dat ik door een "domme" handeling de modem vermoedelijk verneukt heb.
Groetjes,
Steven
				Speedygekko
- Starter
Idd, da's net het probleem en ik heb reeds zitten zoeken naar welke soldeerpunten het zouden moeten zijn, maar ik vind geen enkel aanknopingspunt, behalve dan het feit dat het via dip-switch 4 (de meest rechtse op de tekening op onderstaande link ?) zal moeten gebeuren.r2504 schreef:Het probleem is dat hij niet uitlegt welke dip-switch het precies is... dus je zal eerst de documentatie moeten zoeken van de Pro versie. De soldeerpunten waarover hij het heeft zijn vermoedelijk deze onder de blauwe reset knop (waarvan er dus op je foto twee links, en twee rechts zichtbaar zijn... en dus nog vier verborgen zitten onder de blauwe reset knop).
Bron: http://www.ozcableguy.com/alcatel.asp#reset
How to reset it back to factory defaults
OK, so you've muffed it right up and can't access it anymore?
No problem. It can be reset back to the factory defaults with one of 3 different methods.
Warning. These procedures wipe your existing configurations completely.
(1) Dip Switches
http://www.ozcableguy.com/screenshots/alcatel10.gif
At the back of the Pro, you'll find a block of four tiny dip switches.
Switch the Modem off, and flick the Number 4 switch to the up position.
Switch the modem on, and wait about 30 secs until the power light is blinking Red then Green continuously.
Flick the Number 4 dipswitch back down.
Dus... de twee meest rechtse soldeerpunten op je eerste foto.Speedygekko schreef:Idd, da's net het probleem en ik heb reeds zitten zoeken naar welke soldeerpunten het zouden moeten zijn, maar ik vind geen enkel aanknopingspunt, behalve dan het feit dat het via dip-switch 4 (de meest rechtse op de tekening op onderstaande link ?) zal moeten gebeuren.
Heb je reeds geprobeerd deze kort te sluiten volgens de procedure in je vorige post ?
				Speedygekko
- Starter
Ik heb gisterenavond de twee meest rechtste soldeerpunten kort gesloten met een kort stukje koperen stroomkabel van 2,5mm2, dit met alle risico's vandien en op goed geluk.r2504 schreef: Dus... de twee meest rechtse soldeerpunten op je eerste foto.
Rarara, wonder boven wonder werkte het !
Na de POST (power on self-test) kon ik via Windows, en als de PC een ip-adresje in dezelfde range had, weer aanloggen op de modem (10.0.0.138). Al de pro-functies zijn beschikbaar gebleven, dus ik hoeft de tweak (home-2-pro) niet opnieuw uit te voeren.
Erna heb ik de settings in de modem weer in orde gebracht.
Dit bericht al typende ben ik momenteel via de modem geconnecteerd.
Hartelijk dank voor de moeite en tijd die je in mijn "probleempje" hebt willen/kunnen steken !
Groeten,
S.
				silencer
- Bedankt: 103 keer
Hier ging die hack meteen goed,alleen is de downloadsnelheid beperkt tot 420kB/s,terwijl ik met de linksys 500kB/s haal.(profiel is hetzelfde dacht ik).
Mss kun je upgraden naar de ST 510 software? (mijn model ondersteund dit in ieder geval niet).
				Speedygekko
- Starter
Is er dan iets dat de ST 510 beter maakt dan de Speedtouch Pro ?silencer schreef:Hier ging die hack meteen goed,alleen is de downloadsnelheid beperkt tot 420kB/s,terwijl ik met de linksys 500kB/s haal.(profiel is hetzelfde dacht ik).
Want in dat geval zou ik het overwegen, maar vermits mijn speeds nooit boven de 400 kB/s komen zal ik er geen last van hebben.
				silencer
- Bedankt: 103 keer
betere software:Speedygekko schreef:Is er dan iets dat de ST 510 beter maakt dan de Speedtouch Pro ?silencer schreef:Hier ging die hack meteen goed,alleen is de downloadsnelheid beperkt tot 420kB/s,terwijl ik met de linksys 500kB/s haal.(profiel is hetzelfde dacht ik).
http://www.webblernet.nl/webinterfaces/ ... /index.htm
ondertussen alweer neiuwere interface.
veel eenvoudiger/overzichtelijker in ieder geval.
				Speedygekko
- Starter
Die upgrade van pro naar 510 is onderstaand linkje ?silencer schreef:betere software:
http://www.petri.co.il/upgrade_from_alc ... to_510.htm
				silencer
- Bedankt: 103 keer
ja, alleen vergeet men dat men via telnet veel kan instellen.altijd reset v.d. instellingen doen!Speedygekko schreef:Die upgrade van pro naar 510 is onderstaand linkje ?silencer schreef:betere software:
