Ben ik aansluitbaar voor 12 mbits?
Hebt u vragen of opmerkingen over de speedtest? Deze kan u hier plaatsen
cindra
Hallo
Zou iemand mij kunnen vertellen of ik in aanmerking kan komen voor een 12 mbits lijn?
Scarlet en dommel zegt dat het bij mij zonder problemen kan. Maar vraag het me echt af.
Us Rate (Kbps) 384
Ds Rate (Kbps) 3328
US Margin 25
DS Margin 12
Trained Modulation ADSL_G.dmt
LOS Errors 0
DS Line Attenuation 47
US Line Attenuation 24
Peak Cell Rate 905 cells per sec
CRC Rx Fast 1540
CRC Tx Fast 12
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
Alvast heel erg bedankt
:wink:
svermassen
Uitgedeelde bedankjes: 182 keer
Bedankt: 35 keer
12 Mbit en dan op 4 Mb zetten of zo :lol:
cindra
svermassen schreef:12 Mbit en dan op 4 Mb zetten of zo :lol:
Dus niet haal baar? :!: Max 4mb? :wink:
Dfrog
Bedankt: 22 keer
Noise Margin (AKA Signal to Noise Margin or Signal to Noise Ratio)
Relative strength of the DSL signal to Noise ratio. 6dB is the lowest dB manufactures specify for modem to be able to synch. In some instances interleaving can help raise the noise margin to an acceptable level. The higher the number the better for this measurement.
6dB or below is bad and will experience no synch or intermittent synch problems
7dB-10dB is fair but does not leave much room for variances in conditions
11dB-20dB is good with no synch problems
20dB-28dB is excellent
29dB or above is outstanding
Line Attenuation
Measure of how much the signal has degraded between the DSLAM and the modem. Maximum signal loss recommendation is usually about 60dB. The lower the dB the better for this measurement.
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
Output Power
How much power modem (upstream) or DSLAM (downstream) is using. Maximum recommended is about 15dB. The lower the power the better for this measurement.
Uw attenuation lijkt redelijk hoog volgens deze tabel.
cindra
Line Attenuation
40dB-50dB is good
Output Power
Ja inderdaad
Maar als je een lijn test laat uitvoeren op dommel geeft tie aan dat 12 mbit wel beschikbaar is vraag me dan af wat hier wel beschikbaar zou zijn voor mijn gegevens
SniFManS
hoe ver zit je van de centrale ? Ik kan met de volle zekerheid zeggen dat ze je niet aansluiten op 12mbit profiel als je verder zit dan 4.6 km van een centrale. Omdat ze dan zeggen dat je geen snelheids winst kan boeken .
Terug naar “Speedtest”
