Once again, the alarm bells are going off that the number of IP addresses available on the Internet are running low. This time, there are specific dates for when the addresses are predicted to run out.
The IPv4 Address Report lists two possible dates for when the number of IPv4 dates will run out: April 17, 2010 or December 2, 2010, depending on the source.
The Internet Assigned Numbers Authority (IANA) predicts the April 17 date. It manages IPv4 addresses, but does not handle things like end-users for ISPs. The Regional Internet Registries (RIRs) is a collection of regional bodies that distributed IP addresses to various areas, and made the December 2, 2010 prediction.
Regardless of whether it's April or December of 2010, the time of reckoning is only three years away. Now the American Registry for Internet Numbers (ARIN), the organization responsible for giving out IP addresses in North America, has published a resolution exhorting the industry to get its tail in gear. ARIN is promoting a rapid move to IPv6 (define)ARIN says that 19 percent of the IPv4 addresses are still available, while 68 percent have been allocated and 13 percent are "unavailable," whatever that could mean. There are 4.3 billion IPv4 addresses, or 2^32. IPv6 has 2^128 addresses, or 16 billion-billion.
Bron: http://www.internetnews.com/infra/article.php/3680121
IPv4 Addresses Expected To Run Out In 2010
- Bedankt: 46 keer
Chello ondersteunt native IPv6 en ik "dacht" Evonet ook ...Ofloo schreef:Ik vraag me af hoeveel Belgische ISP's reeds native IPv6 ondersteunen, of er mee bezig zijn.
Weet ook iemand het preciese uurOfloo schreef:The IPv4 Address Report lists two possible dates for when the number of IPv4 dates will run out: April 17, 2010 or December 2, 2010, depending on the source.
- Bedankt: 140 keer
Hmm, betekent dit dan dat er tegen (of ervoor) die datum de IPv4 adressen heel duur gaan worden?
- Sub Zero
- Bedankt: 121 keer
/me strijkr2504 schreef:Weet ook iemand het preciese uurOfloo schreef:The IPv4 Address Report lists two possible dates for when the number of IPv4 dates will run out: April 17, 2010 or December 2, 2010, depending on the source.
Anyway, technieken zoals NAT enzo hebben dit al lange tijd uitgesteld. Het zat er al een beetje aan te komen he
- Bedankt: 663 keer
Eens gevraagd bij dommel, antwoord:
Geachte,
Voorlopig zijn er geen plannen om native ipv6 te ondersteunen.
- deej
- Bedankt: 4 keer
Ja UG heeft bv 8 klasse C's en 1 klasse B en alles krijgt daar een publiek IP...lithion schreef:Ze kunnen er ook eens een paar terugpakken hé. Als je ziet dat sommige universiteiten voor alle pc's in het netwerk een publiek ip kunnen voorzien.
