subject: news-service changes
As of today we have changed our policy regarding the usage of the dommel.com adsl newsservice. There is no longer a 50GB monthly limit on what you download from news.dommel.be. As long as you are connected using broadband you can download from our newsservers. If you are on mediumband you cannot download from news.dommel.be. Alse the max 4-limit connectionlimit has been removed and has been changed by a dynamic limit between 2-12 connections. This means that at peak-moments you might only be able to connect with 2 connections while at lesser busy moments you can use 12 connections. Each connection remains limited to 256 Kbit/sec. At off-peak moments you will be able to download at 3Mbit/sec from our newsservers. There is no general definition to peak or off-peak moments, the server will monitor constantly its current load and adapt the maximum allowed connections on the fly.
Nice
