C:\>tracert groups.google.be
Tracing route to groups.l.google.com [64.233.167.104]
over a maximum of 30 hops:
1 Destination host unreachable.
Trace complete.
Dat is vanaf een WinXP pc.
Andere pc's in m'n LAN kunnen groups.google.be perfect bereiken.
C:\>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=1ms TTL=64
Reply from 10.0.0.1: bytes=32 time<1ms TTL=64
Ping statistics for 10.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\>ping 195.238.2.21
Pinging 195.238.2.21 with 32 bytes of data:
Reply from 195.238.2.21: bytes=32 time=16ms TTL=56
Reply from 195.238.2.21: bytes=32 time=17ms TTL=56
Reply from 195.238.2.21: bytes=32 time=15ms TTL=56
Ping statistics for 195.238.2.21:
Minimum = 15ms, Maximum = 17ms, Average = 15ms
C:\>ping groups.google.be
Pinging groups.l.google.com [64.233.167.104] with 32 bytes of data:
Reply from 64.233.167.104: bytes=32 time=109ms TTL=241
Reply from 64.233.167.104: bytes=32 time=108ms TTL=241
Ping statistics for 64.233.167.104:
Minimum = 108ms, Maximum = 109ms, Average = 108ms
C:\>ping 64.233.167.99
Pinging 64.233.167.99 with 32 bytes of data:
Reply from 64.233.167.99: bytes=32 time=111ms TTL=241
Reply from 64.233.167.99: bytes=32 time=110ms TTL=241
Reply from 64.233.167.99: bytes=32 time=114ms TTL=241
Reply from 64.233.167.99: bytes=32 time=113ms TTL=241
Ping statistics for 64.233.167.99:
Minimum = 110ms, Maximum = 114ms, Average = 112ms
C:\>
Opmerkelijk te vinden dat bij PING wel het juiste IP adres (.104 vanachter) komt te staan.
je routing table ziet er prima uit...
Kan je de web interface van je router en de site van google bereiken door gewoon te surfen?
Als dit het geval is, dan is het enigste wat er mij te binnen schiet je windows firewall, als die op staat kan dit je probleem verklaren.
Joe
Web interface van router en site van google zijn perfect te bereiken.
Met Windows Firewall uit, krijg ik nog steeds dezelfde melding.
