Host unreachable
tsunade
Ik probeer vanop school thuis op mijn pc te gerake, ma het ga ni..
Hier nen traceroute:
[tsunade@pc120 ~]$ traceroute codezero.dynalias.net
traceroute to codezero.dynalias.net (83.217.92.15), 30 hops max, 38 byte packets
 1  10.116.0.2 (10.116.0.2)  0.352 ms  0.335 ms  0.322 ms
 2  10.0.0.100 (10.0.0.100)  0.494 ms  0.400 ms  0.401 ms
 3  193.191.13.9 (193.191.13.9)  0.980 ms  0.719 ms  1.042 ms
 4  oc48.m160.core.science.belnet.net (193.191.1.125)  2.000 ms  1.990 ms  2.070 ms
 5  * oc192.m320.ext.science.belnet.net (193.191.1.2)  2.089 ms  1.959 ms
 6  * * *
 7  ge-0-0-0-bcr2.bru.cw.net (206.24.147.26)  2.396 ms  5.730 ms  2.497 ms
 8  so-5-1-0-dcr1.tsd.cw.net (195.2.10.70)  11.965 ms  11.823 ms  11.508 ms
 9  * so-4-0-0-dcr1.tsd.cw.net (195.2.10.146)  11.740 ms  11.736 ms
10  so-7-0-0-zcr2.lnt.cw.net (166.63.222.42)  12.193 ms  12.230 ms so-1-0-0-zcr1.lnt.cw.net (195.2.10.125)  12.394 ms
11  so-7-0-0-zcr2.lnt.cw.net (166.63.222.42)  12.479 ms  12.261 ms  22.828 ms
12  sl-bb22-lon-8-0.sprintlink.net (213.206.128.60)  14.522 ms  12.399 ms  12.296 ms
13  sl-bb20-bru-14-0.sprintlink.net (213.206.129.42)  16.356 ms sl-bb22-lon-8-0.sprintlink.net (213.206.128.60)  12.389 ms 12.355 ms
14  * sl-bb20-bru-14-0.sprintlink.net (213.206.129.42)  47.855 ms sl-gw10-bru-14-0.sprintlink.net (80.66.128.46)  189.681 ms15  sle-realr-1-0.sprintlink.net (80.66.129.238)  16.539 ms sl-gw10-bru-14-0.sprintlink.net (80.66.128.46)  193.198 ms  203.093 ms
16  ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.225 ms  17.368 ms  16.694 ms
17  * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.118 ms *
18  * * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  16.881 ms !H
19  * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.465 ms !H *
20  * * *
21  * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  16.775 ms !H *
22  * * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.367 ms !H
23  * * *
24  * * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.034 ms !H
25  * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.322 ms !H *
26  * * *
27  * * *
28  * * *
29  * * *
30  * ge0-1-21.dr1.bebru1.realroute.net (83.143.241.50)  17.018 ms !H *
Vanaf 18e hop ziede wel wa het probleem is. Die !H staat voor 'Host unreachable', dus die router kan mijn pc ni bereiken. Wat dus wil zeggen dat de routing op die router ni goe ingesteld is denk ik..
Of wordt het geblokkeerd door ACL ofzo
Sensei Zeon
Als je nu eens zou zeggen wat je juist probeert te bereiken :)
Want het kan even goed zijn dat je school het verkeer dat je probeerd, blokkeert :)
Als er tussenin een router niet pingable is, dan eindigt de traceroute meestal op timeouts ook, dus dit is geen 100% sluitend argument.
tsunade
SeNsEi Ze0n schreef:Als je nu eens zou zeggen wat je juist probeert te bereiken :)
Ik probeer via SSH in te loggen. Ma ik denk ni dat ze die poort geblokeerd hebben ze.. vroeger ging het trouwens wel. Ik kan ook niet op VNC , of bijvoorbeeld ook ni op poort 8080 , kdenk ni da ons school die poorten allemaal geblokkeerd zou hebben. Dus daarom denk ik dat het aan die router ligt.
Astralon
Bedankt: 125 keer
Een poort scan gedaan op 80, 5900, 5901, 8080, enz... maar geen services. IP Addres is ok?
Gr, Astralon
tsunade
Gr, Astralon
IP address is ok ze, is van 'realdsl netwerk',:
[tsunade@pc120 ~]$ nslookup codezero.dynalias.net
Server:         10.6.3.200
Address:        10.6.3.200#53
Non-authoritative answer:
Address: 83.217.92.15
whois 83.217.92.15 ..
SSH en VNC draaien wel op mijn pc, en zijn ook geforward door mijn router, dus daar ligt het ni aan
Astralon
Bedankt: 125 keer
Welke poorten gebruik je precies? 22 (SSH), 5900 (VNC), 5901(VNC), enz...? Ook op poort 8080 is er niet veel te zien :?
Gr, Astralon
Astralon
Bedankt: 125 keer
Ik heb even een VNC sessie gestart op één van onze computers en de poorten op de router geconfigureerd.
Probeer eens met VNC naar 81.246.146.108. Ik ga je geen paswoord geven :P maar je zou verbinding moeten kunnen maken met VNC, tenminste als de poorten op school openstaan.
Gr, Astralon
tsunade
Astralon schreef:Welke poorten gebruik je precies? 22 (SSH), 5900 (VNC), 5901(VNC), enz...? Ook op poort 8080 is er niet veel te zien :?
Gr, Astralon
ja, als host unreachable is, zal je ook ni veel kunne scanne denk ik eh ;)
btw probeer ook ma is andere hosts van realdsl te scanne, die zegge allemaal 'Host unreachable'
Astralon
Bedankt: 125 keer
Gr, Astralon
Ik zal straks eens alle poorten scannen op jouw IP addres 8)
Gr, Astralon
tsunade
Astralon schreef:
Gr, Astralon
Gr, Astralon
awel, da moogde gij van mij ^^
je bedoelt dus als je thuis op realdsl netwerk zit dus, dat je niet langs die ene router moet =].
awel ge zult zien da der dan wel poorte open staan :p
Astralon
Bedankt: 125 keer
tsunade,
Voor alle duidelijkheid: ik run de poort scan van onze servers op het Belgacom netwerk :oops: waar alle poorten openstaan.
Gr, Astralon
tsunade
Astralon schreef:Ik heb even een VNC sessie gestart op één van onze computers en de poorten op de router geconfigureerd.
Gr, Astralon
tuurlijk werkt dit =], dit is geen IP van realdsl netwerk eh.. maar van skynet.
btw ik bedoel die router van realdsl, diegene van de traceroute: ge0-1-21.dr1.bebru1.realroute.net
tsunade
ok, de fout lag dus bij mij :oops:
het ip van codezero.dynalias.net dat in de DNS database zat, was nog een oude.., op mijn router stond een verkeerd DNS server address, daarom werd da ni automatisch ge-update.
Astralon
Bedankt: 125 keer
Kon ook bijna niet anders :wink:
Gr, Astralon
Terug naar “RealDSL”
