Ik beschik over een Synology NAS 420+ met upgrade naar 6GB RAM, alsook in totaal 4x2 TB HDD in SHR (/volume1).
Ik wil graag een ebook bib beheren via Calibre-Web in Docker.
Daartoe installeerde ik eerst een docker image genaamd Calibre met de volgende compose:
services:
calibre:
image: lscr.io/linuxserver/calibre:latest
container_name: calibre
security_opt:
- seccomp:unconfined # optional
environment:
- PUID=1026
- PGID=100
- TZ=Europe/Brussels
- PASSWORD= # optional
- CLI_ARGS= # optional
volumes:
- /volume1/docker/calibre/config:/config
- /volume1/Books/Library:/ebooks
- /volume1/Books/Import:/import
ports:
- 8080:8080
- 8081:8081
restart: unless-stopped
calibre
date stream content
2025/04/26 20:47:14 stderr PermissionError: [Errno 13] Permission denied: '/config/Calibre Library'
2025/04/26 20:47:14 stderr File "os.py", line 225, in makedirs
2025/04/26 20:47:14 stderr File "calibre/gui2/wizard/__init__.py", line 698, in makedirs
2025/04/26 20:47:14 stderr File "calibre/gui2/wizard/__init__.py", line 831, in set_initial_library_location
2025/04/26 20:47:14 stderr Traceback (most recent call last):
2025/04/26 20:47:14 stderr Failed to create /config/.cache for shader cache (Permission denied)---disabling.
2025/04/26 20:47:13 stderr Failed to create /config/.cache for shader cache (Permission denied)---disabling.
2025/04/26 20:47:13 stdout Obt-Message: Xinerama extension is not present on the server
2025/04/26 20:47:13 stderr [mi] mieq: warning: overriding existing handler (nil) with 0x55e7c994ba80 for event 3
2025/04/26 20:47:13 stderr [mi] mieq: warning: overriding existing handler (nil) with 0x55e7c994ba80 for event 2
2025/04/26 20:47:13 stderr Errors from xkbcomp are not fatal to the X server
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86NavInfo
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86SidevuSonar
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86ClearvuSonar
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86TraditionalSonar
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86RadarOverlay
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86DualRangeRadar
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86SingleRangeRadar
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86FishingChart
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86NavChart
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86Sos
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86MarkWaypoint
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86AutopilotEngageToggle
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86PreviousElement
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86NextElement
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86CameraAccessToggle
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86CameraAccessDisable
2025/04/26 20:47:13 stderr > Warning: Could not resolve keysym XF86CameraAccessEnable
2025/04/26 20:47:13 stderr The XKEYBOARD keymap compiler (xkbcomp) reports:
2025/04/26 20:47:13 stdout Openbox-Message: Unable to make directory "/config/.cache/openbox/sessions": Permission denied
2025/04/26 20:47:13 stderr Openbox-Message: 20:47:13.534: Unable to make directory '/config/.cache/openbox': Permission denied
2025/04/26 20:47:13 stderr Underlying X server release 12101012
2025/04/26 20:47:13 stderr See http://kasmweb.com for information on KasmVNC.
2025/04/26 20:47:13 stderr Copyright (C) 1999-2018 KasmVNC Team and many others (see README.me)
2025/04/26 20:47:13 stderr Xvnc KasmVNC 1.3.4 - built Apr 19 2025 19:15:04
2025/04/26 20:47:13 stderr _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
2025/04/26 20:47:13 stdout [ls.io-init] done.
2025/04/26 20:47:13 stdout [custom-init] No custom files found, skipping...
2025/04/26 20:47:13 stdout ───────────────────────────────────────
2025/04/26 20:47:13 stdout Build-date: 2025-04-23T06:51:00+00:00
2025/04/26 20:47:13 stdout Linuxserver.io version: v8.3.0-ls333
2025/04/26 20:47:13 stdout User GID: 100
2025/04/26 20:47:13 stdout User UID: 1026
2025/04/26 20:47:13 stdout GID/UID
2025/04/26 20:47:13 stdout https://www.linuxserver.io/donate/
2025/04/26 20:47:13 stdout To support LSIO projects visit:
2025/04/26 20:47:13 stdout Brought to you by linuxserver.io
2025/04/26 20:47:13 stdout ╚══════╝╚══════╝╚═╝ ╚═════╝
2025/04/26 20:47:13 stdout ███████╗███████║██║╚██████╔╝
2025/04/26 20:47:13 stdout ██║ ╚════██║██║██║ ██║
2025/04/26 20:47:13 stdout ██║ ███████╗██║██║ ██║
2025/04/26 20:47:13 stdout ██║ ██╔════╝██║██╔═══██╗
2025/04/26 20:47:13 stdout ██╗ ███████╗██╗ ██████╗
2025/04/26 20:47:12 stdout usermod: no changes
2025/04/26 20:47:12 stdout [migrations] no migrations found
2025/04/26 20:47:12 stdout [migrations] started
2025/04/26 20:46:55 stdout No write access to /config/.config/calibre using a temporary dir instead
2025/04/26 20:46:55 stderr The X11 connection broke (error 1). Did the X11 server die?
2025/04/26 20:46:55 stderr X connection to :1 broken (explicit kill or server shutdown).
2025/04/26 20:44:47 stderr PermissionError: [Errno 13] Permission denied: '/config/Calibre Library'
2025/04/26 20:44:47 stderr File "os.py", line 225, in makedirs
2025/04/26 20:44:47 stderr File "calibre/gui2/wizard/__init__.py", line 698, in makedirs
2025/04/26 20:44:47 stderr File "calibre/gui2/wizard/__init__.py", line 831, in set_initial_library_location
2025/04/26 20:44:47 stderr Traceback (most recent call last):
2025/04/26 20:44:46 stderr Failed to create /config/.cache for shader cache (Permission denied)---disabling.
2025/04/26 20:44:43 stderr Openbox-Message: 20:44:43.276: Unable to make directory '/config/.cache/openbox': Permission denied
2025/04/26 20:44:43 stderr [mi] mieq: warning: overriding existing handler (nil) with 0x5634c25b8a80 for event 3
2025/04/26 20:44:43 stderr [mi] mieq: warning: overriding existing handler (nil) with 0x5634c25b8a80 for event 2
2025/04/26 20:44:43 stderr Errors from xkbcomp are not fatal to the X server
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86NavInfo
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86SidevuSonar
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86ClearvuSonar
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86TraditionalSonar
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86RadarOverlay
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86DualRangeRadar
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86SingleRangeRadar
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86FishingChart
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86NavChart
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86Sos
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86MarkWaypoint
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86AutopilotEngageToggle
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86PreviousElement
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86NextElement
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86CameraAccessToggle
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86CameraAccessDisable
2025/04/26 20:44:43 stdout Obt-Message: Xinerama extension is not present on the server
2025/04/26 20:44:43 stdout Openbox-Message: Unable to make directory "/config/.cache/openbox/sessions": Permission denied
2025/04/26 20:44:43 stderr > Warning: Could not resolve keysym XF86CameraAccessEnable
2025/04/26 20:44:43 stderr The XKEYBOARD keymap compiler (xkbcomp) reports:
2025/04/26 20:44:42 stderr
2025/04/26 20:44:42 stderr Underlying X server release 12101012
2025/04/26 20:44:42 stderr See http://kasmweb.com for information on KasmVNC.
2025/04/26 20:44:42 stderr Copyright (C) 1999-2018 KasmVNC Team and many others (see README.me)
2025/04/26 20:44:42 stderr Xvnc KasmVNC 1.3.4 - built Apr 19 2025 19:15:04
2025/04/26 20:44:42 stderr _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
2025/04/26 20:44:42 stdout Openbox-Message: Failed to open the display from the DISPLAY environment variable.
2025/04/26 20:44:42 stdout Openbox-Message: Unable to make directory "/config/.cache/openbox/sessions": Permission denied
2025/04/26 20:44:42 stderr Openbox-Message: 20:44:42.250: Unable to make directory '/config/.cache/openbox': Permission denied
2025/04/26 20:44:40 stdout [ls.io-init] done.
2025/04/26 20:44:40 stdout [custom-init] No custom files found, skipping...
2025/04/26 20:44:40 stderr -----
2025/04/26 20:44:40 stderr .+.....+.........+...+.......+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*..+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*................+.....+...+.+.....+............+....+......+...............+..+.+..+...............+..........+..+.+............+........+.+.....+...+.+..+...+......+.+..+..........+...........+.........+...+....+...+..................+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2025/04/26 20:44:39 stderr ..............+....+......+...+..+.........+.+...+...+...+..+...+......+...+.......+...........+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*......+................+.....+....+..............+....+..+....+......+...........+...+....+.....+.+......+........+.+...........+.+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*...+...+...+....+........+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2025/04/26 20:44:39 stdout
2025/04/26 20:44:39 stdout ───────────────────────────────────────
2025/04/26 20:44:39 stdout Build-date: 2025-04-23T06:51:00+00:00
2025/04/26 20:44:39 stdout Linuxserver.io version: v8.3.0-ls333
2025/04/26 20:44:39 stdout User GID: 100
2025/04/26 20:44:39 stdout User UID: 1026
2025/04/26 20:44:39 stdout GID/UID
2025/04/26 20:44:39 stdout https://www.linuxserver.io/donate/
2025/04/26 20:44:39 stdout To support LSIO projects visit:
2025/04/26 20:44:39 stdout Brought to you by linuxserver.io
2025/04/26 20:44:39 stdout ╚══════╝╚══════╝╚═╝ ╚═════╝
2025/04/26 20:44:39 stdout ███████╗███████║██║╚██████╔╝
2025/04/26 20:44:39 stdout ██║ ╚════██║██║██║ ██║
2025/04/26 20:44:39 stdout ██║ ███████╗██║██║ ██║
2025/04/26 20:44:39 stdout ██║ ██╔════╝██║██╔═══██╗
2025/04/26 20:44:39 stdout ██╗ ███████╗██╗ ██████╗
2025/04/26 20:44:37 stdout [migrations] no migrations found
2025/04/26 20:44:37 stdout [migrations] started
chown -R 1026:100 /volume1/docker/calibre/config
Vervolgens installeer ik calibre-web met de volgende docker compose:
services:
calibre-web:
image: lscr.io/linuxserver/calibre-web:latest
container_name: calibre-web
environment:
- PUID=1026
- PGID=100
volumes:
- /volume1/docker/calibre-web/config:/config
- /volume1/Books/Library:/books
ports:
- 8083:8083
Meldt elke browser mij hetzelfde probleem:
This site can’t be reached
The connection was reset.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_RESETCode: Selecteer alles
2025/04/26 21:02:42 stderr (Background on this error at: https://sqlalche.me/e/20/e3q8)
2025/04/26 21:02:42 stderr ]
2025/04/26 21:02:42 stderr )
2025/04/26 21:02:42 stderr UNIQUE (email)
2025/04/26 21:02:42 stderr UNIQUE (name),
2025/04/26 21:02:42 stderr kobo_only_shelves_sync INTEGER,
2025/04/26 21:02:42 stderr view_settings JSON,
2025/04/26 21:02:42 stderr allowed_column_value VARCHAR,
2025/04/26 21:02:42 stderr denied_column_value VARCHAR,
2025/04/26 21:02:42 stderr allowed_tags VARCHAR,
2025/04/26 21:02:42 stderr denied_tags VARCHAR,
2025/04/26 21:02:42 stderr default_language VARCHAR(3),
2025/04/26 21:02:42 stderr sidebar_view INTEGER,
2025/04/26 21:02:42 stderr locale VARCHAR(2),
2025/04/26 21:02:42 stderr kindle_mail VARCHAR(120),
2025/04/26 21:02:42 stderr password VARCHAR,
2025/04/26 21:02:42 stderr role SMALLINT,
2025/04/26 21:02:42 stderr email VARCHAR(120),
2025/04/26 21:02:42 stderr name VARCHAR(64),
2025/04/26 21:02:42 stderr id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT,
2025/04/26 21:02:42 stderr CREATE TABLE user (
2025/04/26 21:02:42 stderr [SQL:
2025/04/26 21:02:42 stderr sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) attempt to write a readonly database
2025/04/26 21:02:42 stderr cursor.execute(statement, parameters)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 945, in do_execute
2025/04/26 21:02:42 stderr self.dialect.do_execute(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1964, in _exec_single_context
2025/04/26 21:02:42 stderr raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2352, in _handle_dbapi_exception
2025/04/26 21:02:42 stderr self._handle_dbapi_exception(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1983, in _exec_single_context
2025/04/26 21:02:42 stderr ^^^^^^^^^^^^^^^^^^^^^^^^^^
2025/04/26 21:02:42 stderr return self._exec_single_context(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1843, in _execute_context
2025/04/26 21:02:42 stderr ret = self._execute_context(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1527, in _execute_ddl
2025/04/26 21:02:42 stderr return connection._execute_ddl(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/ddl.py", line 187, in _execute_on_connection
2025/04/26 21:02:42 stderr return meth(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1416, in execute
2025/04/26 21:02:42 stderr return bind.execute(self)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/ddl.py", line 321, in _invoke_with
2025/04/26 21:02:42 stderr ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025/04/26 21:02:42 stderr )._invoke_with(self.connection)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/ddl.py", line 1019, in visit_table
2025/04/26 21:02:42 stderr return meth(obj, **kw)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/visitors.py", line 664, in traverse_single
2025/04/26 21:02:42 stderr self.traverse_single(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/ddl.py", line 981, in visit_metadata
2025/04/26 21:02:42 stderr visitorcallable(self.dialect, self, **kwargs).traverse_single(element)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2456, in _run_ddl_visitor
2025/04/26 21:02:42 stderr conn._run_ddl_visitor(visitorcallable, element, **kwargs)
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 3249, in _run_ddl_visitor
2025/04/26 21:02:42 stderr bind._run_ddl_visitor(
2025/04/26 21:02:42 stderr File "/lsiopy/lib/python3.12/site-packages/sqlalchemy/sql/schema.py", line 5925, in create_all
2025/04/26 21:02:42 stderr Base.metadata.create_all(engine)
2025/04/26 21:02:42 stderr File "/app/calibre-web/cps/ub.py", line 700, in init_db
2025/04/26 21:02:42 stderr ub.init_db(cli_param.settings_path)
2025/04/26 21:02:42 stderr File "/app/calibre-web/cps/__init__.py", line 123, in create_app
2025/04/26 21:02:42 stderr app = create_app()
2025/04/26 21:02:42 stderr File "/app/calibre-web/cps/main.py", line 31, in main
2025/04/26 21:02:42 stderr main()
2025/04/26 21:02:42 stderr File "/app/calibre-web/cps.py", line 47, in <module>
2025/04/26 21:02:42 stderr Traceback (most recent call last):
2025/04/26 21:02:42 stderr The above exception was the direct cause of the following exception:
2025/04/26 21:02:42 stderr sqlite3.OperationalError: attempt to write a readonly database
2025/04/26 21:02:40 stdout [custom-init] No custom files found, skipping...
2025/04/26 21:02:40 stdout Could not set binary paths for '/config/app.db' (see errors above).
2025/04/26 21:02:40 stderr Parse error near line 1: no such table: settings
2025/04/26 21:02:36 stdout First time run, creating app.db...
2025/04/26 21:02:36 stdout ───────────────────────────────────────
2025/04/26 21:02:36 stdout User GID: 100
2025/04/26 21:02:36 stdout User UID: 1026
2025/04/26 21:02:36 stdout GID/UID
2025/04/26 21:02:36 stdout https://www.linuxserver.io/donate/
2025/04/26 21:02:36 stdout To support LSIO projects visit:
2025/04/26 21:02:36 stdout Brought to you by linuxserver.io
2025/04/26 21:02:36 stdout ╚══════╝╚══════╝╚═╝ ╚═════╝
2025/04/26 21:02:36 stdout ███████╗███████║██║╚██████╔╝
2025/04/26 21:02:36 stdout ██║ ╚════██║██║██║ ██║
2025/04/26 21:02:36 stdout ██║ ███████╗██║██║ ██║
2025/04/26 21:02:36 stdout ██║ ██╔════╝██║██╔═══██╗
2025/04/26 21:02:36 stdout ██╗ ███████╗██╗ ██████╗
2025/04/26 21:02:33 stdout [migrations] no migrations found
2025/04/26 21:02:33 stdout [migrations] started
...terwijl ik dezelfde truukjes toepas als hierboven:
chown -R 1026:100 /volume1/docker/calibre-web/config
chown -R 1026:100 /volume1/Books/Library
sudo docker exec -it calibre-web ls -l /booksCode: Selecteer alles
total 1076
drwxrwxrwx 1 abc users 154 Apr 24 19:36 'Adler Olsen, Jussi'
drwxrwxrwx 1 abc users 180 Apr 24 22:26 'Alexandre Dumas'
drwxrwxrwx 1 abc users 38 Apr 24 19:49 'Alex North'
drwxrwxrwx 1 abc users 44 Apr 24 22:26 'Allan Folsom'
drwxrwxrwx 1 abc users 42 Apr 24 22:21 'Arthur Conan Doyle'
drwxrwxrwx 1 abc users 80 Apr 24 19:47 'BA Paris'
drwxrwxrwx 1 abc users 42 Apr 24 19:35 'Boyne, John'
drwxrwxrwx 1 abc users 70 Apr 24 19:38 'Cecelia Ahern'
drwxrwxrwx 1 abc users 82 Apr 24 22:21 'Charles Dickens'
drwxrwxrwx 1 abc users 30 Apr 24 22:20 'Charlotte Bronte'
drwxrwxrwx 1 abc users 58 Apr 24 19:48 'Clare Mackintosh'
drwxrwxrwx 1 abc users 56 Apr 24 22:26 'Cornelis Johannes Kieviet'
drwxrwxrwx 1 abc users 44 Apr 24 19:45 'Cornwell, Patricia'
drwxrwxrwx 1 abc users 46 Apr 24 22:25 'Cyriel Buysse'
drwxrwxrwx 1 abc users 78 Apr 24 19:49 'Delia Owens'
drwxrwxrwx 1 abc users 28 Apr 24 22:25 'Emile Zola'
drwxrwxrwx 1 abc users 134 Apr 24 19:43 'Emily Barr'
drwxrwxrwx 1 abc users 40 Apr 24 22:22 'Frederick Marryat'
drwxrwxrwx 1 abc users 48 Apr 24 22:21 'G. A. Henty'
drwxrwxrwx 1 abc users 62 Apr 24 19:46 'Gillian Flynn'
drwxrwxrwx 1 abc users 78 Apr 24 19:44 'Goddard, Robert'
drwxrwxrwx 1 abc users 38 Apr 24 22:24 'Gustave Flaubert'
drwxrwxrwx 1 abc users 642 Apr 24 19:43 'Harlan Coben'
drwxrwxrwx 1 abc users 40 Apr 24 22:25 'Harm Boom'
drwxrwxrwx 1 abc users 84 Apr 24 22:26 'Hendrik Conscience'
drwxrwxrwx 1 abc users 88 Apr 24 22:23 'Honore de Balzac'
drwxrwxrwx 1 abc users 298 Apr 24 19:44 'James Patterson'
drwxrwxrwx 1 abc users 48 Apr 24 22:19 'Jane Austen'
drwxrwxrwx 1 abc users 24 Apr 24 22:24 'Jean de La Fontaine'
drwxrwxrwx 1 abc users 16 Apr 24 19:47 'Jeroen Olyslaegers'
drwxrwxrwx 1 abc users 226 Apr 24 19:42 'John Boyne'
drwxrwxrwx 1 abc users 30 Apr 24 19:43 'John Grisham'
drwxrwxrwx 1 abc users 42 Apr 23 18:47 'John Schember'
drwxrwxrwx 1 abc users 76 Apr 24 19:44 'Jonathan Safran Foer'
drwxrwxrwx 1 abc users 44 Apr 24 19:48 'J.P. Delaney'
drwxrwxrwx 1 abc users 90 Apr 24 22:25 'Jules Verne'
drwxrwxrwx 1 abc users 36 Apr 24 19:49 'Julia Crouch'
drwxrwxrwx 1 abc users 100 Apr 24 19:41 'Jussi Adler-Olsen'
drwxrwxrwx 1 abc users 32 Apr 24 19:45 'Karin Slaughter'
drwxrwxrwx 1 abc users 30 Apr 24 19:45 'Lee Child'
drwxrwxrwx 1 abc users 76 Apr 24 22:20 'Lewis Carroll'
drwxrwxrwx 1 abc users 24 Apr 24 19:28 'L.S. Hilton'
drwxrwxrwx 1 abc users 96 Apr 24 19:49 'Lucinda Riley'
drwxrwxrwx 1 abc users 68 Apr 24 22:22 'Mark Twain'
-rwxrwxrwx 1 abc users 1085440 Apr 26 16:31 metadata.db
-rwxrwxrwx 1 abc users 14069 Apr 26 18:07 metadata_db_prefs_backup.json
drwxrwxrwx 1 abc users 188 Apr 24 19:46 'Michael Berg'
drwxrwxrwx 1 abc users 72 Apr 24 19:48 'Michael Robotham'
drwxrwxrwx 1 abc users 28 Apr 24 19:48 Oorsprong
drwxrwxrwx 1 abc users 62 Apr 24 19:45 'Patricia Cornwell'
drwxrwxrwx 1 abc users 196 Apr 24 19:44 'Patterson, James'
drwxrwxrwx 1 abc users 34 Apr 24 19:47 'Paula Hawkins'
drwxrwxrwx 1 abc users 74 Apr 24 22:22 'PocketBook International SA'
drwxrwxrwx 1 abc users 56 Apr 24 19:45 'Rachel Simon'
drwxrwxrwx 1 abc users 206 Apr 24 19:42 'Rene Appel'
drwxrwxrwx 1 abc users 46 Apr 24 19:48 'Riley Sager'
drwxrwxrwx 1 abc users 166 Apr 24 19:46 'Robert Goddard'
drwxrwxrwx 1 abc users 110 Apr 24 19:48 'Ruth Ware'
drwxrwxrwx 1 abc users 44 Apr 24 19:47 'Sarah Pinborough'
drwxrwxrwx 1 abc users 44 Apr 24 19:46 'Sebastian Fitzek'
drwxrwxrwx 1 abc users 62 Apr 24 19:41 'Sharon Bolton'
drwxrwxrwx 1 abc users 28 Apr 24 19:40 'S.J. Bolton'
drwxrwxrwx 1 abc users 50 Apr 24 22:24 Stendhal
drwxrwxrwx 1 abc users 48 Apr 24 19:48 Vriendschapsverzoek
drwxrwxrwx 1 abc users 74 Apr 24 22:22 'W.H.G. Kingston'
sudo docker exec -it calibre ls -l /library
total 1076
Geen idéé waar het fout loopt, maar ik ben ten einde raad
(edit: typo, evident 6GB RAM
