Non-living things have a gender !
Teebee
Bedankt: 40 keer
You may not know this but many nonliving things have a gender.
1) Ziploc Bags are Male, because they hold everything in, but you
can see right through them.
2) Copiers are Female, because once turned off; it takes a while to
warm them up again. It's an effective reproductive device if the right
buttons are pushed, but can wreak havoc if the wrong buttons are pushed.
3) A Tire is Male, because it goes bald and it's often
over-inflated.
4) A Hot Air Balloon is Male, because, to get it to go anywhere, you
have to light a fire under it, and of course, there's the hot air part.
5) Sponges are Female, because they're soft, squeezable and retain
water.
6) A Web Page is Female, because it's always getting hit on.
7) A Subway is Male, because it uses the same old lines to pick
people up.
8) An Hourglass is Female, because over time, the weight shifts to
the bottom.
9) A Hammer is Male, because it hasn' t changed much over the last
5,000 years, but it's handy to have around.
10) A Remote Control is Female. Ha! (You thought it'd be male,
didn't you?) But consider this - it gives a man pleasure, he'd be lost
without it, and while he doesn't always know the right buttons to push, he keeps trying!
Styno
:-D dat zijn pas quotes die goed zouden passen in een signature ;)
CiBi
allemaal zou een beetje veel worden
STARBUCKS  : CPU : Intel i5-540M (2x2.53Ghz) , RAM : 4GB , HD : 500GB , GRAKA : GeForce GT 330M + onboard Intel HD Graphics , OS : X.6 Snow Leopard 64bit , SCREEN : 17" 1920x1200 LED-backlit widescreen [laptop]
Robbe
El Robre
El Robre
Twitter: infocaris
wel goeikes :-)
