een gelijkaardige klacht stond al ergens anders op deze site maar zal ff mijn tutorial van op mijn site erop pleuren
sorry dat het in het engels is (heb het namelijk op een engelse site gepost!)
hi all, this is my first tutorial and I have written it because me, myself and I suffered a lot of a trojan so called "browser hijacker" as far as I now it isn't detected by Nav corporate, spybot search & destroy or ad-aware!
probably a lot will think "wtf is a browserhijacker??!!!" didn't you dios??
well to explain it shortly:
browserhijacker is a trojan that resets your homepage to a site you really don't want as a homepage! you can't repair it with the above named apps. even if you manually reset your homepage to your favorite site (wareznet of courser or pr0n like 8ball's homepage!) but!!! after rebooting... OH NO!!! 1'VE B33N H4X0R3D!! would tygaer say you guessed it the stupid site's back!
that's what it is, now how to fix the damn bitch!!
firstly you have to download two small freeware apps!
here are the links==>::
http://mjc1.com/mirror/hjt/ (not a direct link cos on this site they give some information also!
and the other one
http://www.merijn.org/files/CWShredder.exe
so now you have the 2 small apps!
1)firstly manually set your homepage to whatever you like!
2) what you gonna launch is hijack this and let it scan, you'll see some info
so you'll basically need to fix the following all the lines with the url of the homepage in it!, it's not difficult but DON'T DELETE THE OTHER STUFF!!!
I'm not responsible, if you don't know post your scans here and I'll try to point what to fix!
2)second step is to run CWshredder, read the info that pops up and let it scan for the trojan and bogus registry files , it will repair and remove what's wrong! *edit* seems there is an update so before scanning make sure you update it*edit*
3) to test if the shitty bitch isn't back after rebooting: reboot and open your browser!
4)!!!FIXED!!!
Tutorial written by me and tested by me!
problems?? or server of the apps are down, reply here or if the apps are offline contact me on irc and I'll dcc them to you! (they are really small)
I'm only online wednesday noonn till 8 (west europeantime: Brussels-Amsterdam-Paris)
and in the weekends from noon till 6 AM(WET)
PS: update ad-aware or spybot search en destroy and all the other apps often!
