Hoi iedereen, bedankt voor het meedenken. Ik was er even 2 weken tussenuit en heb me dit weekend weer op het probleem gesmeten.
Met de server expire had ik al zitten spelen, 300, 1000, 3600 maakt allemaal niet veel uit.
Port forwarding heb ik niet nog niet echt naar gekeken is wel een piste die ik wil bekijken.
Probleem is er nog altijd, heb de indruk dat het erger en erger aan het worden is. Bellen lukt nu compleet niet meer (telkens verboden) en oproepen gaan gewoon over maar komen niet meer binnen.
Netwerk:
PPPoE sessie op de USG van de bbox3
Hier alvast een logje:
<134>Apr 23 21:11:21 sua [912]: APP <6+info > [SIP] <IPC_rcv >:msg:0x00041102, wparam:0x00000000, lparam:0x00008001, id:SIP_C2S_CALL_NEW_OUTGOING
<133>Apr 23 21:11:21 sua [912]: APP <5+notice> [SIP] SIP_C2S_CALL_NEW_OUTGOING, lid:0, cid:32769,callmask:0x00000000,callee:0479XXXXXX
<134>Apr 23 21:11:21 sua [912]: SUA <6+info > [000] ****API Event:(0x0001) SIPUA_EVENT_A2S_INVITE ****
<134>Apr 23 21:11:21 GUI [1107,1107]: URIL<6+info > CCSTAProcesser::SendEvent[13]
<134>Apr 23 21:11:21 sua [912]: CAL <6+info > [000] pickup_index: -1, bla_index: -1, mask: 0x0, enable pickup: 0, remote: 0479XXXXXX on behalf:
<134>Apr 23 21:11:21 sua [912]: FSM <6+info > [000] allocating transaction ressource 6 0_1450085192
<134>Apr 23 21:11:21 sua [912]: FSM <6+info > [000] allocating ICT context
<134>Apr 23 21:11:21 sua [912]: DNS <6+info > [SIP] A query ims.scarlet.be: find from cache
<133>Apr 23 21:11:21 sua [912]: CAL <5+notice> [000] call status update [0]==>[2]
<133>Apr 23 21:11:21 sua [912]: DLG <5+notice> [000] Message sent: (to dest=80.200.255.199:5060 len=939)
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000]
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] INVITE sip:[email protected]:5060 SIP/2.0
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Via: SIP/2.0/UDP 192.168.1.99:5060;branch=z9hG4bK2869131394
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] From: "Home" <sip:[email protected]:5060>;tag=3367385898
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] To: <sip:[email protected]:5060>
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Call-ID: [email protected]
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] CSeq: 1 INVITE
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Contact: <sip:[email protected]:5060>
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Content-Type: application/sdp
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Max-Forwards: 70
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] User-Agent: Yealink W52P 25.81.188.8 001565f93297
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Allow-Events: talk,hold,conference,refer,check-sync
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Supported: replaces
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Content-Length: 306
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] v=0
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] o=- 20000 20000 IN IP4 192.168.1.99
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] s=SDP data
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] c=IN IP4 192.168.1.99
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] t=0 0
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] m=audio 12544 RTP/AVP 9 0 8 18 101
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=rtpmap:9 G722/8000
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=rtpmap:0 PCMU/8000
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=rtpmap:8 PCMA/8000
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=rtpmap:18 G729/8000
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=fmtp:18 annexb=no
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=ptime:20
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=sendrecv
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=rtpmap:101 telephone-event/8000
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] a=fmtp:101 0-15
<133>Apr 23 21:11:21 sua [912]: NET <5+notice> [000] ===>>>> UDP socket 80.200.255.199:5060: send 939 bytes
<133>Apr 23 21:11:21 sua [912]: NET <5+notice> [255] <<<<=== UDP socket 80.200.255.199:5060: read 297 bytes
<134>Apr 23 21:11:21 sua [912]: SIP <6+info > [SIP] match line:name:+3251XXXXXX host:ims.scarlet.be
<133>Apr 23 21:11:21 sua [912]: DLG <5+notice> [000] Message recv: (from src=80.200.255.199:5060 len=297)
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] SIP/2.0 100 Trying
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Via: SIP/2.0/UDP 192.168.1.99:5060;received=62.235.XXX.XX;branch=z9hG4bK2869131394;rport=5060
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] Content-Length: 0
<133>Apr 23 21:11:21 sua [912]: NET <5+notice> [255] <<<<=== UDP socket 80.200.255.199:5060: read 328 bytes
<134>Apr 23 21:11:21 sua [912]: SUA <6+info > [000] ****eCore event:(0x0010)ECORE_CALL_PROCEEDING ****
<133>Apr 23 21:11:21 sua [912]: DLG <5+notice> [000] Message recv: (from src=80.200.255.199:5060 len=328)
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] SIP/2.0 403 Forbidden
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] To: <sip:[email protected]:5060>;tag=aprqngfrt-7u3ncp1000020
<134>Apr 23 21:11:21 sua [912]: CAL <6+info > [000] Call proceeding cid 32769
<133>Apr 23 21:11:21 sua [912]: DLG <5+notice> [000] Message sent: (to dest=80.200.255.199:5060 len=316)
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] ACK sip:[email protected]:5060 SIP/2.0
<134>Apr 23 21:11:21 sua [912]: DLG <6+info > [000] CSeq: 1 ACK
<133>Apr 23 21:11:21 sua [912]: NET <5+notice> [000] ===>>>> UDP socket 80.200.255.199:5060: send 316 bytes
<134>Apr 23 21:11:21 sua [912]: SUA <6+info > [000] ****eCore event:(0x0014)ECORE_CALL_REQUESTFAILURE ****
<134>Apr 23 21:11:21 sua [912]: CAL <6+info > [000] recv call failure msg event 14, cid 32769, code: 403 call type:0
<134>Apr 23 21:11:21 sua [912]: APP <6+info > [SIP] <IPC_ntfp>:msg=0x00040106, wparam=0, lparam=32769, size=136, id=SIP_CALL_FAIL
<133>Apr 23 21:11:21 sua [912]: CAL <5+notice> [000] call status update [2]==>[19]
Nummers en IP aangepast.
