7590
Taal: Meertalig
Version: 07.39-94458
Datum: 09.02.2022
Fritzbox 7590/7530/6890 LTE whitelisting + Supervectoring 35b
Hello.
According to edpnet page:
https://www.edpnet.be/en/support/orderi ... dpnet.html
FRITZ!Box 7530 AX German version (MPN: 20002930 / EAN: 4023125029301) is not supported.
Could please somebody confirm, that this is a valid statement?
Do I need to have global only version of this modem in order to use with edpnet VDSL ?
- Bedankt: 2998 keer
This statement is obsolete now. There are no differences any more between German and international versions, both hardware and Firmware are identical.
Also the statement that "German versions don’t have edpnet configuration preset and you will need to select Other Internet Provider and manually enable VLAN10 in order to successfully configure the device" is not correct.
As soon as you change the country settings to Belgium, and reboot the Fritz!Box, the "Belgian" provider dropdown list with the Edpnet configuration will be available.
Most important is the DSL driver, which needs to be whitelisted. In some cases you may need to select "previous driver" in order to avoid a "fall back" profile (capped to 7 Mbps).
- Uitgedeelde bedankjes: 457 keer
- Bedankt: 313 keer
de DSL/telefoon stekker in de fritzbox 7590 stoppen (DE versie) is toch niet simpel. In de bbox 3V+ glijdt hij erin.....
Verschil met de internat. box?
7590
DSL-versie: 1.180.131.98
Meertalig
Version: 07.39-94931
Datum: 03.03.2022
Vorige week is s'nachts een update gebeurd (vergeten autom. updaten uit te schakelen). s'morgens gaat alles zo traag bij thuiswerken. Doe een speedtest, zat op FB profiel 5/0.5
. Edpnet gebeld, binnen de min. binnen, en 2 minuten later terug 50 DL.
Dus 'previous dsl driver aanzetten' + updates UITSCHAKELEN!
Nu terug manueel nieuwe driver ingeschakeld om op FB profiel te vallen. Nadien Bbox 3V+, en dan kan ik aan 35 Mbps profiel raken ipv 30 Mbps (fritzbox).![Smile :-)](./images/smilies/icon_smile.gif)
7590
Meertalig
Datum: 03.03.2022
![Sad :-(](./images/smilies/icon_sad.gif)
- lacer
- Bedankt: 133 keer
De DSL stekker voor in een Fritzbox heeft een RJ45 body met de 2 middelste pinnen in gebruik.
Op en Bbox-3 is dit een RJ11.
Normaal dat deze RJ11 moeilijk erin gaat
Bij de Fritzbox is toch een grijs DSL kabeltje bijgeleverd ?
https://assets.avm.de/files/docs/fritzb ... _nl_BE.pdf
pagina 41
![Very Happy :-D](./images/smilies/icon_biggrin.gif)
pagina 41
EdpNet XL 99/35 Mbps
RPi 2B + 3B +3B+ Kodi
Ubuntu Mate 18.04
Ubuntu Mate 18.04
Er is geen verschil tussen een Duitse of internationale FB.satsurfer schreef:de DSL/telefoon stekker in de fritzbox 7590 stoppen (DE versie) is toch niet simpel. In de bbox 3V+ glijdt hij erin.....
Let wel op: een RJ11 stekker steken in een RJ45 bus kan deze laatste beschadigen.
Bij een internationale FB wordt een kabeltje geleverd met aan de ene kant een RJ45 stekker, en aan de andere kant een RJ11 stekker.lacer schreef: Normaal dat deze RJ11 moeilijk erin gaat![]()
Bij de Fritzbox is toch een grijs DSL kabeltje bijgeleverd?
Ofwel een Y-kabel met de nodige adapters.
- Bedankt: 313 keer
7590
DSL-versie: 1.180.129.93 (previous)
Meertalig
Version: 07.39-95462
Datum: 25.03.2022
New features:
- Talking caller ID – FRITZ!Fon learns to speak: New features for FRITZ!Fon
- WireGuard support for simple setup of VPN connections
- Mesh Wi-Fi – more performance for the FRITZ!Box as a Mesh Repeater
- More operating convenience in the FRITZ!Box user interface
Meertalig
Datum: 25.03.2022
New features:
- Bedankt: 313 keer
7590
Meertalig
Version:07.39-95780 (Beta)
Datum: 08.04.2022
Meertalig
Datum: 08.04.2022
Laatst gewijzigd door satsurfer op 26 apr 2022, 18:24, 2 keer totaal gewijzigd.
- alloja
- Bedankt: 37 keer
Op Bel-Com is er een gebruiker van 7590 AX die zonder fallback werkt!
Proximus Epic Combo Fiber: 1Gbps/200Mbps + Pickx Mix + Mobilus Unlimited Premium
Net: Internet Box & FRITZ!Box 4060
TV: V5 & V7 + Apple TV 4K
