Trage snelheid
Geplaatst: 29 jul 2004, 23:27
Diagnostics
System
Product Name = SpeedTouch 510
Vendor Name = THOMSON
Software Version = 4.2.3.0.1
Serial Number = 0407FGK86
CLI Version = 1.2.0
Bootloader Version = 2.0.5
ASIC Version = 1b01
Board Name = ADNT-Q
Modem Label Version = 2.11.28
Lan
Ethernet
Interface name = eth0
Physical address = 00:90:d0:d9:1d:49
Physical Interface 1
Mode = forwarding
Auto Negotiation = Yes
Type = 100BaseTFD
kBytes Tx/Rx = 879 / 288
Frames Tx/Rx = 2988 / 2608
Discarded frames = 7
Wan
Dsl
DSL Flavour = ADSL over POTS
Reserved Bandwidth (kbit/s) up/down = 384 / 7232
Uptime = 00:00:59
kBytes Tx/Rx = 4 / 4
Properties
Output Power (dBm) up/down = 12 / 19
Attenuation (dB) up/down = 23 / 39
Noise Margin (dB) up/down = 21 / 6
Vendor Id (local/remote) = ALCB / GSPN
Statistics
Loss of signal (local/remote) = 0 / 0
Loss of power (local/remote) = 0 / 0
Loss of framing (local/remote) = 0 / 0
Errored Seconds (local/remote) = 5 / 1
Loss of link (remote) = 0
Connections
pppoe_pppoe
Connection Type = PPPoE
kBytes Tx/Rx = 0 / 0
Username = A04133003@A2F
Password = ********
Access Concentrator = 90052010193568-kpn_be_vil_rb01
Service Name = Not Configured
Last Connection Error = None
Uptime = 00:00:21
IP Connectivity
Ping Address = 81.89.96.11
Ping Address Description = Primary DNS server (specified by IPCP)
Ping Roundtrip Time (in msec) = 158
Ping Packetsize (in bytes) = 20
IP
Local IP Address = 81.89.118.xx
Remote IP Address = 81.89.118.xx
Other IP Addresses = Not Configured
Primary DNS = 81.89.96.11
Secondary DNS = 81.89.96.12
MTU Size = 1492
Address Translation = pat
UnicastPackets Tx/Rx = 3 / 4
BroadcastPackets Tx/Rx = 0 / 0
Packets Dropped = 0
PPP
Username = "username"@A2F
Password = ********
MRU Size = 1492
Admin. State = up
Oper. State = up
Link State = connected
LCP State = opened
IPCP State = opened
Retry interval = 10
PPPoE
RELAY
Interface Admin. State = Up
PPPoE relay session id = 1 (client)
Relay portlist
format: ETH Intf (Status) [-> Phonebook Name(Address,QoS [,autoconfigured])]
1. ethoa_pppoe (up) -> pppoe (8.35, ubr)
2. eth0 (up)
Ethernet
Interface Name = ethoa_pppoe
Interface Type = ETHoA
Interface Admin. State = connected
ATM
Phonebook Name = pppoe
Address = 8.35
Encapsulation = llc/snap
Auto Configured = no
QoSbook Name = default
QoS Type = ubr
LOG
00:00:51
PPP CHAP Chap receive success : authentication ok
00:00:50
PPP CHAP Receive challenge (rhost = kpn_be_vil_rb01)
00:00:45
xDSL linestate up (downstream: 7232 kbit/s, upstream: 384 kbit/s)
00:00:06
LOGIN User XXX logged in on HTTP (from 10.0.0.39)
00:00:00
DHCP server up
00:00:00
KERNEL Cold restart
System
CLI Version = 1.2.0
ASIC Version = 1b01
Board Name = ADNT-Q
Lan
Ethernet
Mode = forwarding
Type = 100BaseTFD
Wan
Dsl
Uptime = 00:00:59
Properties
Statistics
Connections
pppoe_pppoe
Password = ********
Uptime = 00:00:21
IP Connectivity
IP
MTU Size = 1492
Packets Dropped = 0
PPP
Password = ********
MRU Size = 1492
Admin. State = up
Oper. State = up
LCP State = opened
IPCP State = opened
Retry interval = 10
PPPoE
RELAY
Relay portlist
2. eth0 (up)
Ethernet
ATM
Address = 8.35
QoS Type = ubr
LOG
00:00:51
00:00:50
00:00:45
00:00:06
00:00:00
DHCP server up
00:00:00
KERNEL Cold restart
Modbreak:
SeNsEi Ze0n
SeNsEi Ze0n
