stof in de gsm
Geplaatst: 12 okt 2015, 09:00
door johand
In het weekend wat in de tuin gewerkt, en MOTO G heeft blijikbaar wat aarde/stif gevreten. Wanneer ik nu bel hoor ik de andere, maar met een snerpend geluid erbij. uitblazen met de compressor heeft niet echt verbetring gebracht; Tips?
Re: stof in de gsm
Geplaatst: 12 okt 2015, 09:39
door Dima_2005
Mogelijk is zelfs speaker defect geraakt... Iig zal je het moeten openschroeven
Re: stof in de gsm
Geplaatst: 12 okt 2015, 12:00
door Argon
Oorzaak is niet volledig dezelfde, maar je kan het altijd eens proberen... :
Users have reported some audio issues with the Moto G, including a buzzing earpiece, and a generally poor audio quality from the external speaker as well as the headphone jack.
Potential Solution –
If you hear a buzzing sound on the earpiece during a call, you should first test it to see whether there is an issue with the earpiece itself. To do so, you have to first make sure that USB Debugging is enabled, by going into Settings – Developer Options – USB Debugging. Then dial *#*#2486#*#* in the dialer, and that should open up the test menu. Select the first bar, then select Audio, click on Earpiece, and choose Buzz Test. Hold the phone to your ear, and you will hear a harmonic sound that starts on a lower frequency and goes to an higher frequency, that will repeat. If you don’t hear any distortion in this loop that is played, then there are no issues with your earpiece at all.
If you do have a faulty earpiece, the only solution is to go pick up a replacement device. If there’s nothing wrong with the device, then go into Settings – Sound – Audio Effects, and turn it off. If that doesn’t work, in the Audio effects section, go into Speaker, and turn the equalizer off. That should do the trick, but if it doesn’t you may need to flash a lower firmware version. You can find out more about that process here.
If you’re facing any other issues with audio quality, go into Audio Effects, and you can change the equalizer settings in the Wired Stereo and Speaker sections separately.
Re: stof in de gsm
Geplaatst: 12 okt 2015, 12:47
door brubbel
compressor
Re: stof in de gsm
Geplaatst: 12 okt 2015, 13:20
door johand
compressor = lucht blazen
Re: stof in de gsm
Geplaatst: 12 okt 2015, 13:33
door Dima_2005
Met een compressor kon je mogelijk zelfs de speaker beschadigen... Of andere onderdelen.
Re: stof in de gsm
Geplaatst: 12 okt 2015, 13:34
door brubbel
Dat klopt, als het flinderdunne membraan van de speaker maar niet gescheurd is.
Re: stof in de gsm
Geplaatst: 12 okt 2015, 14:42
door johand
dan was dat niet verstandig van mij. Hij is er in ieder geval niet slechter door gaan klinken.
Re: stof in de gsm
Geplaatst: 13 okt 2015, 11:15
door johand
Argon schreef:Oorzaak is niet volledig dezelfde, maar je kan het altijd eens proberen... :
Thx, dit heeft geholpen, ik kan voorlopig verder zonder een nieuwe earspeaker te laten plaatsen.
