Heeft vdsl nog zin !!!!!!!
Geplaatst: 29 apr 2014, 23:19
Als ik deze bekijk kan mijn VDSL lijn eigenlijk 100 mbit download halen ( in maart was het 57 mbit )
Maar alles wordt netjes begrensd op 30 mbit .
Wordt deze onnozele spel van cappen ooit opgelosd .
Laat zoals onze buurlanden gewoon internetten op snelheid wat men kan en niet wat men wil toelaten omwille van
onnezele oorlog tussen sips .
MVG
DEZE IS VAN VANDAAG
active profiel 30/6
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 34528 kbps
Upstream line rate: 7392 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 30040 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 6048 kbps
Downstream attainable payload rate: 100764 kbps
Downstream attainable line rate: 120992 kbps
Downstream Training Margin: 30.4 dB
Downstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb500494b4e530000
Downstream delay: 7.5 ms
Upstream delay: 5.4 ms
Tx total power -25.5 dbm
FE Tx total power 12.0 dbm
VDSL Estimated Loop Length : 254 ft
G.Hs Estimated Near End Loop Length : 1589 ft
G.Hs Estimated Far End Loop Length :288 ft
Current framing mode: 0x10
DEZE IS VAN 5 MAART 2014
( 25/10 PROFIEL high upload )
Bme: 1 Port: 1
Downstream line rate: 30400 kbps
Upstream line rate: 12256 kbps
Bearer1 Downstream payload rate: 25184 kbps
Bearer1 Upstream payload rate: 10048 kbps
Downstream attainable payload rate: 57560 kbps
Downstream attainable line rate: 72296 kbps
Downstream Training Margin: 27.8 dB
Downstream Line Protection (Bearer1 Path): 4.0 DMT Symbols
Downstream delay: 14.4 ms
Upstream delay: 5.5 ms
Tx total power -25.2 dbm
FE Tx total power 10.2 dbm
VDSL Estimated Loop Length : 215 ft
G.Hs Estimated Near End Loop Length : 1595 ft
G.Hs Estimated Far End Loop Length :264 ft
MVG
DEZE IS VAN VANDAAG
active profiel 30/6
Bme: 1 Port: 1
Bme: 1 Port: 1
