bbox 2 nieuw firmware ( vectoring ready )
Geplaatst: 05 maa 2014, 20:29
Gisteren nacht gebeurd denk ik
hier is het dan
60R10J-60A07C
Firmware-VTU-R:9.5.7.12IK105012 Time Jan 10 2014, 22:12:04
info via telnet
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 30400 kbps
Upstream line rate: 12256 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 25184 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 10048 kbps
Downstream attainable payload rate: 57560 kbps
Downstream attainable line rate: 72296 kbps
Downstream Training Margin: 27.8 dB
Downstream Line Protection (Bearer1 Path): 4.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb500494b4e530000
Downstream delay: 14.4 ms
Upstream delay: 5.5 ms
Tx total power -25.2 dbm
FE Tx total power 10.2 dbm
VDSL Estimated Loop Length : 215 ft
G.Hs Estimated Near End Loop Length : 1595 ft
G.Hs Estimated Far End Loop Length :264 ft
Current framing mode: 0x10
Bandplan Type...........: 2
No. of Upstream Bands...: 2
No. of Downstream Bands.: 3
hier is het dan
60R10J-60A07C
info via telnet
Bme: 1 Port: 1
