Tunlr-Clone
Geplaatst: 27 feb 2014, 08:32
door B3NJAMIN
Ik heb sinds gisteren de Tunrl-Clone (https://github.com/corporate-gadfly/Tunlr-Clone) geinstalleerd op een VPS (BuyVM).
Op de computer werkt het daar kan ik netflix content afspelen, maar zodra ik de DNS ingeef in de Boxee Box geeft netflix de melding "cannot connect to netflix".
Weet er iemand mss of ik nog een adres in "zones.override" moet zetten? Ik weet niet meer wat ik nog kan veranderen..
named.conf.options
options {
directory "/var/cache/bind";
forwarders {
# these are the DNS servers from the VPS provider (look in /etc/resolv.conf if yours are different)
205.185.112.68;
8.8.8.8;
auth-nxdomain no; # conform to RFC1035
listen-on-v6 { any; };
allow-query { trusted; };
allow-recursion { trusted; };
recursion yes;
dnssec-enable no;
dnssec-validation no;
named.conf.local
// Do any local configuration here
// Consider adding the 1918 zones here, if they are not used in your
// organization
//include "/etc/bind/zones.rfc1918";
include "/etc/bind/rndc.key";
acl "trusted" {
172.16.11.146; // local venet0:17 internal IP here
127.0.0.1;
81.244.210.19; // Your ISP IP here (cable/DSL)
include "/etc/bind/zones.override";
zones.override
zone "hulu.com." {
type master;
file "/etc/bind/db.override";
zone "huluim.com." {
type master;
zone "netflix.com." {
type master;
zone "abc.com." {
type master;
zone "abc.go.com." {
type master;
zone "fox.com." {
type master;
zone "link.theplatform.com." {
type master;
zone "nbc.com." {
type master;
zone "nbcuni.com." {
type master;
zone "pandora.com." {
type master;
zone "broadband.espn.go.com." {
type master;
type master;
zone "nbc.com." {
type master;
type master;
type master;
type master;
zone "ip2location.com." {
type master;
zone "boxee.tv" {
type master;
db.override
; BIND data file for overridden IPs
$TTL 86400
@ IN SOA ns1 root (
2012100401 ; serial
604800 ; refresh 1w
86400 ; retry 1d
2419200 ; expiry 4w
86400 ; minimum TTL 1d
; need atleast a nameserver
IN NS ns1
; specify nameserver IP address
ns1 IN A 209.141.50.121 ; external IP from venet0:0
; provide IP address for domain itself
@ IN A 209.141.50.121 ; external IP from venet0:0
; resolve everything with the same IP address as ns1
* IN A 209.141.50.121 ; external IP from venet0:0
Sniproxy.conf
user daemon
pidfile /var/tmp/sniproxy.pid
listener 172.16.11.146:80 {
protocol http
listener 172.16.11.146:443 {
protocol tls
table {
(hulu|huluim)\.com *
abc\.(go\.)?com *
(nbc|nbcuni)\.com *
netflix\.com *
ip2location\.com *
boxee\.tv *
Re: Tunlr-Clone
Geplaatst: 28 feb 2014, 14:26
door B3NJAMIN
Blijkbaar zit er een fout in sniproxy, ik heb een issue geopend op github.
