NAS miserie
Geplaatst: 20 okt 2013, 03:54
door Heronic
Setup :
Moederbord : MSI C847MS-E33
Voeding : Corsair HX650 (ms vervangen door een 430)
Extra sata controller 1 : HighPoint Rocket 640L - Storage controller (RAID) - 4 Kanaal - SATA 6Gb/s low profile - 600 MBps - RAID 0, 1, JBOD - PCIe 2.0 x4
Extra sata controller 2 : ? vanonder het stof gehaald.
OS : Openmediavault (debian)
HDs :
3x hotswap in de case.
7x Hotswap icy box ib-170sk-b
Probleem :
Schijven gaan offline.
[ 1255.169349] sd 7:0:0:0: [sdd] CDB: Read(16): 88 00 00 00 00 01 5d 50 a3 88 00 00 00 08 00 00
[ 1255.169366] end_request: I/O error, dev sdd, sector 5860533128
[ 1255.169445] __ratelimit: 40 callbacks suppressed
[ 1255.169449] Buffer I/O error on device sdd, logical block 732566641
[ 1255.171078] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171083] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171088] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 09 00 00 00 08 00
[ 1255.171101] end_request: I/O error, dev sdd, sector 2304
[ 1255.171177] Buffer I/O error on device sdd, logical block 288
[ 1255.171343] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171346] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171351] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 40 00 00 08 00
[ 1255.171361] end_request: I/O error, dev sdd, sector 2112
[ 1255.171435] Buffer I/O error on device sdd, logical block 264
[ 1255.171615] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171618] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171622] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.171633] end_request: I/O error, dev sdd, sector 2064
[ 1255.171707] Buffer I/O error on device sdd, logical block 258
[ 1255.171813] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171816] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171821] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.171831] end_request: I/O error, dev sdd, sector 2064
[ 1255.171904] Buffer I/O error on device sdd, logical block 258
[ 1255.172007] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.172009] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.172014] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.172024] end_request: I/O error, dev sdd, sector 2064
[ 1255.172097] Buffer I/O error on device sdd, logical block 258
[ 1255.172198] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.172201] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.172205] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.172215] end_request: I/O error, dev sdd, sector 2064
[ 1255.172288] Buffer I/O error on device sdd, logical block 258
[ 1255.179808] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.179814] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.179819] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 88 00 00 00 08 00 00
[ 1255.179836] end_request: I/O error, dev sdc, sector 7814037128
[ 1255.179915] Buffer I/O error on device sdc, logical block 976754641
[ 1255.180269] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.180273] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.180277] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 09 00 00 00 08 00
[ 1255.180289] end_request: I/O error, dev sdc, sector 2304
[ 1255.180363] Buffer I/O error on device sdc, logical block 288
[ 1255.181090] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.181094] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.181099] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 08 40 00 00 08 00
[ 1255.181111] end_request: I/O error, dev sdc, sector 2112
[ 1255.181186] Buffer I/O error on device sdc, logical block 264
[ 1255.182239] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.182244] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.182248] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 0a 00 00 00 08 00
[ 1255.182260] end_request: I/O error, dev sdc, sector 2560
[ 1255.191530] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191536] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191542] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 00 00 00 00 08 00 00
[ 1255.191559] end_request: I/O error, dev sdc, sector 7814036992
[ 1255.191701] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191706] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191711] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 bd a8 00 00 00 08 00 00
[ 1255.191728] end_request: I/O error, dev sdc, sector 7814036904
[ 1255.191838] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191841] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191846] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 70 00 00 00 08 00 00
[ 1255.191861] end_request: I/O error, dev sdc, sector 7814037104
[ 1255.191984] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191987] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191992] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192002] end_request: I/O error, dev sdc, sector 56
[ 1255.192098] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192101] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192105] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192115] end_request: I/O error, dev sdc, sector 56
[ 1255.192208] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192210] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192215] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192225] end_request: I/O error, dev sdc, sector 56
[ 1255.192317] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192320] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192324] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192334] end_request: I/O error, dev sdc, sector 56
[ 1255.192427] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192430] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192434] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192444] end_request: I/O error, dev sdc, sector 120
[ 1255.192536] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192539] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192543] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192554] end_request: I/O error, dev sdc, sector 120
[ 1255.192647] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192650] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192654] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192664] end_request: I/O error, dev sdc, sector 120
[ 1255.192758] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192761] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192765] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192775] end_request: I/O error, dev sdc, sector 120
[ 1255.192893] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192896] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192900] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192911] end_request: I/O error, dev sdc, sector 56
[ 1255.193003] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193006] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193010] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.193021] end_request: I/O error, dev sdc, sector 56
[ 1255.193112] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193115] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193119] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.193129] end_request: I/O error, dev sdc, sector 120
[ 1255.193652] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193655] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193660] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.193670] end_request: I/O error, dev sdc, sector 120
[ 1255.193772] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193775] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193779] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.193789] end_request: I/O error, dev sdc, sector 64
[ 1255.193880] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193883] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193887] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.193897] end_request: I/O error, dev sdc, sector 64
[ 1255.193988] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193991] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193995] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194005] end_request: I/O error, dev sdc, sector 64
[ 1255.194094] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194097] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194101] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194111] end_request: I/O error, dev sdc, sector 64
[ 1255.194202] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194204] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194210] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194221] end_request: I/O error, dev sdc, sector 64
[ 1255.194470] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194474] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194478] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194488] end_request: I/O error, dev sdc, sector 64
[ 1255.194580] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194583] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194587] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194597] end_request: I/O error, dev sdc, sector 64
[ 1255.194687] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194690] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194694] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194704] end_request: I/O error, dev sdc, sector 64
[ 1255.194794] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194797] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194801] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194811] end_request: I/O error, dev sdc, sector 64
[ 1255.194900] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194903] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194907] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194918] end_request: I/O error, dev sdc, sector 64
[ 1255.195008] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195010] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195015] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 00 00 00 08 00
[ 1255.195025] end_request: I/O error, dev sdc, sector 256
[ 1255.195115] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195118] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195122] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 00 00 00 08 00
[ 1255.195132] end_request: I/O error, dev sdc, sector 256
[ 1255.195222] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195225] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195229] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 08 00 00 08 00
[ 1255.195240] end_request: I/O error, dev sdc, sector 264
[ 1255.195329] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195332] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195336] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 08 00 00 08 00
[ 1255.195347] end_request: I/O error, dev sdc, sector 264
[ 1255.195436] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195439] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195444] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 10 00 00 08 00
[ 1255.195454] end_request: I/O error, dev sdc, sector 272
[ 1255.195543] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195546] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195551] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 10 00 00 08 00
[ 1255.195561] end_request: I/O error, dev sdc, sector 272
[ 1255.195652] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195655] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195659] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 00 00 00 08 00
[ 1255.195669] end_request: I/O error, dev sdc, sector 768
[ 1255.195760] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195763] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195767] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 00 00 00 08 00
[ 1255.195777] end_request: I/O error, dev sdc, sector 768
[ 1255.195867] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195870] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195874] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 08 00 00 08 00
[ 1255.195884] end_request: I/O error, dev sdc, sector 776
[ 1255.195974] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195977] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195981] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 08 00 00 08 00
[ 1255.195991] end_request: I/O error, dev sdc, sector 776
[ 1255.196082] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196084] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196089] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 10 00 00 08 00
[ 1255.196099] end_request: I/O error, dev sdc, sector 784
[ 1255.196189] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196191] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196196] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 10 00 00 08 00
[ 1255.196206] end_request: I/O error, dev sdc, sector 784
[ 1255.196309] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196312] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196316] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 02 00 00 00 08 00
[ 1255.196326] end_request: I/O error, dev sdc, sector 512
[ 1255.196426] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196429] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196433] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 10 00 00 00 08 00
[ 1255.196443] end_request: I/O error, dev sdc, sector 4096
Ik dacht eerst dat het aan de voeding zou gelegen hebben. Is getest, kan niet. Voeding is ok.
Toen dacht ik dat het aan de icyboxes zou gelegen hebben (stroomschommelingen ofzo). Is getest, kan niet.
Nu denk ik dat het aan de sata controller ligt.
onboard(sataII) -> pci-e(sataIII) = miserie. <- kan ook omgekeerde volgorde zijn.
onboard(sataII) -> onboard(sataII) = succes.
pci-e(sataIII) -> pci-e(sataIII) = volgende test.
Zal dus eens naar de firmware/drivers van die kaart moeten kijken.
http://www.highpoint-tech.com/USA_new/s ... wnload.htm
Native linux support. Driver piste dus uitgesloten.
Sta open voor tips :x
Re: NAS miserie
Geplaatst: 20 okt 2013, 11:08
door Mathy
Ik heb hier ook een Highpoint kaartje met "native Linux support" liggen, niets als miserie mee gehad, sinds dat ik dat gewisseld heb voor een 3ware loopt alles als een trein. De investering is duurder maar ik heb wel geen corrupte RAIDs meer en een constant hoge throughput.
Dit gezegd zijnde, die fouten kunnen wijzen op:
* probleem met de SATA controller
* probleem met de drivers
* probleem met de kabels
* probleem met de schijven
Als je de laatste twee al uitgesloten hebt kan je eens proberen met een Windows en die drivers (werkte bij mij wel zonder problemen, maar nog geen hoge throughput). Als het dan wel werkt zijn het de linux-drivers. Als het dan nog niet werkt is het de SATA controller.
En nog even om je te doen kwijlen:
barabas ~ # dd if=/dev/md4 of=/dev/null bs=64M count=32
32+0 records in
32+0 records out
2147483648 bytes (2.1 GB) copied, 4.72934 s, 454 MB/s
Dat haalde ik nooit met dat Highpoint spul.
Re: NAS miserie
Geplaatst: 20 okt 2013, 11:10
door Heronic
Schijven en kabels zijn ok. Windows is geen optie.
Welke van 3ware heb je? Linux?
Re: NAS miserie
Geplaatst: 20 okt 2013, 11:18
door Mathy
Linux ja,
06:00.0 RAID bus controller: 3ware Inc 9650SE SATA-II RAID PCIe (rev 01)
Ben niet zeker van het juiste type, zou ik de kast terug open moeten doen. Het is er eentje die 24 drives ondersteunt. Ik denk deze:
http://store.lsi.com/index.cfm/3ware-Co ... 650SE-24M8
Ik heb hem overigens tweedehands gekocht, via Kapaza, nieuw kosten die +1000 euro.
PS: ik stel Windows enkel voor als een test, desnoods plug je dat kaartje ergens in een Windows-pc om gewoon even te proberen.
Re: NAS miserie
Geplaatst: 20 okt 2013, 11:20
door Heronic
woooot
Nu eens testen of van disk naar disk binnen deze highpoint een probleem geeft.
Ziet er goed voorlopig goed uit.
Voorlopige conclusie :
Samenwerking onboard sata(II) en highpoint sata(III) is een probleem.
Zou het kunnen dat deze 2 niet goed samenwerken waardoor sataII <-> sataIII de boel verkloot? Gaat dit opgelost zijn met een andere kaart? Of is sataII <-> sataIII altijd een probleem als het over verschillende controllers loopt.
Het is geen raid trouwens. Ik poog mijn schijven eerst eens te ordenen :cry:
EDIT : Te vroeg geroepen. Van de ene connector naar de andere op de highpoint is ook miserie alleen duurt het wat langer. Soiezo andere kaart dus.
In hoeverre is het ok om een multiplier te gebruiken?
Op een kaart als deze : Areca ARC-1224-8i hoe sluit je daar je sata op aan?
Re: NAS miserie
Geplaatst: 20 okt 2013, 12:29
door Mathy
Daar heb je een break-out cable voor nodig (zoek op SFF, is de naam van die connector). Vaak worden die wel bij die kaarten geleverd.
http://www.alternate.be/DeLOCK/DeLOCK+m ... ent=search
Re: NAS miserie
Geplaatst: 20 okt 2013, 18:28
door Heronic
Zijn er ook "goedkopere" sata controllers die deftig werken(goede reputatie) onder linux? Geen raid voorwaarden.
Wel minstens 4xsataIII.
http://tweakers.net/pricewatch/286496/s ... p-mv8.html
Is nog schappelijk van prijs maar precies toch ook beter geschikt voor windows dan voor linux.
Het is deze geworden lijkt goed te werken onder linux :
http://tweakers.net/pricewatch/291869/i ... tem-x.html
Mijn handjes jeuken al!
Re: NAS miserie
Geplaatst: 21 okt 2013, 09:19
door ubremoved_539
Heronic schreef:Zijn er ook "goedkopere" sata controllers die deftig werken(goede reputatie) onder linux? Geen raid voorwaarden.
Kijk eens op e-Bay naar PERC controllers... worden veel gebruikt door tweakers (heb er zelf ook één) en kan je wel vinden voor een redelijke prijs.
Re: NAS miserie
Geplaatst: 21 okt 2013, 20:52
door Sub Zero
Alles van LSI is ook nog schappelijk van prijs.
Re: NAS miserie
Geplaatst: 21 okt 2013, 21:05
door Heronic
Die serveraid is al onderweg, heb enkele kaartjes genomen en eens gegoogled naar problemen en ervaringen (debian / linux) . Veel positiefs over deze kaart.
Re: NAS miserie
Geplaatst: 24 okt 2013, 17:35
door Heronic
Serveraid m1015 ....
Bij het opstarten die ik de kaart, de kaart herkent de aangesloten schijven, ik kan ook in de bios van de kaart.
Mooi.. maar geen enkel os dat de kaart herkent. :bang:
Binnenkort eens het "te koop" forum spammen met alle onderdelen dit is echt om de muren van op te lopen.
Re: NAS miserie
Geplaatst: 25 okt 2013, 12:20
door ubremoved_539
Heronic schreef:Mooi.. maar geen enkel os dat de kaart herkent. :bang:
Heb je de drivers gedownload... over welk OS spreek je ?
Re: NAS miserie
Geplaatst: 25 okt 2013, 12:35
door mailracer
Enkele jaren geleden heb ik ook gesukkeld met dergelijke issues. Bleek toen aan de harde schijven zelf te liggen. Tenzij je natuurlijk 100 percent zeker bent dat je schijven raid ondersteunen. De samsung 204UI hadden problemen tot ik de firmware heb geupdate.
Bestaat er van die kaartjes geen lijsten met compatibele schijven ?
Re: NAS miserie
Geplaatst: 25 okt 2013, 13:54
door ubremoved_539
Het OS moet de kaart zelfs herkennen zonder schijven !
Re: NAS miserie
Geplaatst: 25 okt 2013, 20:46
door Sub Zero
mailracer schreef:Tenzij je natuurlijk 100 percent zeker bent dat je schijven raid ondersteunen.
Dit is met verve de uitspraak van de week denk ik. Dat is zoals zeggen dat je auto geen airco ondersteunt.
Ik denk dat ik weet wat je bedoelt, maar de manier waarop je het verwoordt is nogal ongelukkig.
Re: NAS miserie
Geplaatst: 05 jan 2014, 20:25
door Heronic
De serveraid moest dus geflashed worden naar lsi.
http://www.servethehome.com/ibm-serveraid-m1015-part-4/
