Fritzbox 7390 and new firmware
Geplaatst: 26 apr 2013, 19:21
door bombus
I have a fritz box 7390 , new firmware , if I want to increase the stability ,or inp , (e.g) , rthe Belgacom line is out (the stabililty is also awful) Do you have such problems.
Thanks in advance
Re: Fritzbox 7390 and new firmware
Geplaatst: 29 apr 2013, 20:33
door bombus
Back to old firmware everything ok !
Geplaatst: 30 apr 2013, 12:25
door fryelectro
I don't have stability issues (I do see some Errors (ES)at the "DSL Telephone switch" which I've never seen before) with the new firmware BUT since I applied it, a few hours later I was forced back to my provisiong profile of 30/6 instead of 70/6... It is not sure that the firmware upgrade has something to do with it, but in the three years I am connected to VDSL2, I was never set on a lower profile....
Geplaatst: 30 apr 2013, 19:09
door bombus
For my own part the profile in snr was doing "yoyo" . In order to stabilise I did what I always did and then no connxion at all . As a result two interventions of a technician and two ports out , so I go back to the old firmware and no problem anymore
So I think there is a problem !
Geplaatst: 30 apr 2013, 20:56
door philippe_d
If you really want some help from the Forum community, you should give a few more details of your xDSL subscription, e.g.
  • - are you ADSL2+ or VDSL2 ?
    - what is your modem sync speed?
    - line values (attenuation, snr)?
    - last but not least: how does your internal wiring look like (starting from the Belgacom wallplate, splitter/filter, etc ..)
I don't believe your problems are related to the fritzBox firmware!
Geplaatst: 30 apr 2013, 21:34
door bombus
So
I am in VDS2, distance from the ROP followin g Hierzo : 354 m , followin Belgacom 498 m
You'll find here after all my data
Sorry but my Nederlands is niet goed
The problems came when I did the upgrade and I want to stabilise my line
Thank you for your help
PS no problem (physical problem on my line) but a "perturbating neighbour" normally SNR equal to to 20 dB but I have this problem.
All the data are very good except this
Geplaatst: 10 mei 2013, 18:49
door snakeboots
Here also with the new firmware two VDSL ports out of service by playing with the increase the stability function. Now I'm using my b-box2 in bridge mode and all works smoothly.
