Homelink software crashed
Geplaatst: 15 okt 2008, 12:17
Ik heb vandaag mijn Gigaset box gekregen en heb de Homelink software geinstalleerd en geupdate, maar bij het vervolledigen van mijn adresgegevens (stap 7) crashed de software altijd. Is er iets wat ik kan doen? Ik heb al geprobeerd om het 0800 nummer te bellen dat in de Homelink software wordt vermeld, maar daar neemt precies niemand de telefoon op.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '0' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ListView.SelectedListViewItemCollection.get_Item(Int32 index)
at dommel.be_Home_Link.Wizard_Reg.PageChange(Object sender, WizardCancelPageChangeEventArgs e)
at DevComponents.DotNetBar.Wizard.OnWizardPageChanging(WizardCancelPageChangeEventArgs e)
at DevComponents.DotNetBar.Wizard.1EV(WizardPage 9D0, eWizardPageChangeSource 9D1)
at DevComponents.DotNetBar.Wizard.NavigateNext()
at DevComponents.DotNetBar.Wizard.1EO(Object 9CQ, EventArgs 9CR)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.ButtonX.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
dommel.com homelink
Assembly Version: 2.0.1.0
Win32 Version: 2.0.1
CodeBase: file:///c:/Program%20Files/dommel.com/dommel.com%20homelink/dommel.com%20homelink.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
y1x75jrd
csumv0gk
pw2by0d1
DevComponents.DotNetBar2
Assembly Version: 6.9.0.1
Win32 Version: 6.9.0.1
CodeBase: file:///c:/Program%20Files/dommel.com/dommel.com%20homelink/DevComponents.DotNetBar2.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Dommel.Link.Siemens
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///c:/Program%20Files/dommel.com/dommel.com%20homelink/Dommel.Link.Siemens.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
