Siemens SSH info
Geplaatst: 24 jun 2008, 23:16
door Ken
ManagementServer.URL = http://xxx4335xxx.dommel.com (wat aangepast)
ManagementServer.Username = 0001E3-CPE-xxxxxxxxxxx (wat aangepast)
ManagementServer.Password = (blanco?)
ManagementServer.PeriodicInformEnable = 0
ManagementServer.PeriodicInformInterval = 240
ManagementServer.PeriodicInformTime = 0001-01-01T00:00:00
ManagementServer.ParameterKey =
ManagementServer.ConnectionRequestURL = http://83.101.15.95:8085/CPE-ACCESS
ManagementServer.ConnectionRequestUsername = (blanco?)
ManagementServer.ConnectionRequestPassword = (blanco?)
ManagementServer.UpgradesManaged = 1
ManagementServer.ManageableDeviceNumberOfEntries = 0
ManagementServer.V_ConnectionRequestPort = 8085
ManagementServer.V_ConnectionRequestAuthentication = None
ManagementServer.V_Interface =
ManagementServer.V_Enable = 0
ManagementServer.V_WaitForNTPSync = 0
ManagementServer.ParameterHash =
Paar SIP instellingen:
Services.VoiceService.1.VoiceProfile.1.SIP.ProxyServer = 83.101.17.xxx
Services.VoiceService.1.VoiceProfile.1.SIP.ProxyServerPort = 5060
Services.VoiceService.1.VoiceProfile.1.SIP.ProxyServerTransport = UDP
Services.VoiceService.1.VoiceProfile.1.SIP.RegistrarServer = 83.101.17.xxx
Services.VoiceService.1.VoiceProfile.1.SIP.RegistrarServerPort = 5060
Services.VoiceService.1.VoiceProfile.1.SIP.RegistrarServerTransport = UDP
Services.VoiceService.1.VoiceProfile.1.SIP.UserAgentDomain = 83.101.17.xxx
Services.VoiceService.1.VoiceProfile.1.SIP.UserAgentPort = 5060
Services.VoiceService.1.VoiceProfile.1.SIP.UserAgentTransport = UDP
Services.VoiceService.1.VoiceProfile.1.SIP.OutboundProxy =
Services.VoiceService.1.VoiceProfile.1.SIP.OutboundProxyPort = 5060
Services.VoiceService.1.VoiceProfile.1.SIP.Organization =
Services.VoiceService.1.VoiceProfile.1.SIP.RegistrationPeriod = 480
Services.VoiceService.1.VoiceProfile.1.SIP.RegisterExpires = 600
Services.VoiceService.1.VoiceProfile.1.SIP.RegisterRetryInterval = 30
Services.VoiceService.1.VoiceProfile.1.SIP.UseCodecPriorityInSDPResponse = 1
Services.VoiceService.1.VoiceProfile.1.SIP.DSCPMark = 26
Services.VoiceService.1.VoiceProfile.1.SIP.V_ProxyServerType = standard
Services.VoiceService.1.VoiceProfile.1.SIP.V_SIPRealm =
Services.VoiceService.1.VoiceProfile.1.SIP.V_SupportsLooseRouting = 1
Services.VoiceService.1.VoiceProfile.1.SIP.V_Send100Trying = 1
Services.VoiceService.1.VoiceProfile.1.Line.1.Enable = Enabled
Services.VoiceService.1.VoiceProfile.1.Line.1.Status = Up
Services.VoiceService.1.VoiceProfile.1.Line.1.CallState = Idle
Services.VoiceService.1.VoiceProfile.1.Line.1.V_RegistrationState = register_reason_none
Services.VoiceService.1.VoiceProfile.1.Line.1.SIP.V_CallerIdName = 0xxxxxxxx (mijn vast tel. nummer)
Services.VoiceService.1.VoiceProfile.1.Line.1.SIP.AuthUserName = sipxxxxx (mijn sip account)
Services.VoiceService.1.VoiceProfile.1.Line.1.SIP.AuthPassword =
Services.VoiceService.1.VoiceProfile.1.Line.1.SIP.URI = sipxxxxx (mijn sip account)
Verder geen wachtwoord te zien, misschien dat het te zien is door te sniffen maar heb geen zin om dat vanavond nog te doen...
Geplaatst: 24 jun 2008, 23:25
door icekiller2k6
ken we zijn zielsgenoten...
in de dll's etc is niets te vinden (toch nog niets tegen gekomen)
en om nu met softice te gaan werken ^^
heb je per toeval ergens de setting gevonden waardoor hij het SIP gedeelte lockt?
Geplaatst: 24 jun 2008, 23:35
door Ken
icekiller2k6 schreef:heb je per toeval ergens de setting gevonden waardoor hij het SIP gedeelte lockt?
Nog niet
Heel wat settings daarin wete...
Geplaatst: 24 jun 2008, 23:37
door icekiller2k6
true hehe ik kan pas vanaf morgen sniffen..
hopelijk kan ik op packet niveau het pakketje deruit halen of zorgen dat hij delock functie niet doet.. mss via SSH de lock functie eruithalen..
in theorie kun je dit doen:
alles zelf configgen met uw informatie zodat het 100% hetzelfde is als wat dommel doet behalve dat het niet gelockt is.
de config daarvan saven.
dan dommel soft laten instellen.
deze config ook saven. Hexidecimaal vergelijken en zien wat verandert is. de dommelconfig dan aanpassen zodat die hex waarde hetzelfde is als de hexwaarde van org. en zo dan toch aan het SIP gedeelte kunnen
wat mss belachelijk is als je zo al de info hebt maar is gewoon leuk om te doen hehe
Geplaatst: 24 jun 2008, 23:53
door Ken
Hmmmz...
Op gathering.tweakers.net:
Net gezien dat er meerdere ssh logins zijn.
Ene met 'operator' en zelfde wachtwoord en ook 'subscriber'...
BlindWillie schreef op zondag 19 augustus 2007 @ 11:10 ...
VOIP-wachtwoord: het is me gelukt dit, in ieder geval voor een deel, te achterhalen. Vanaf de CLI kun je nl. de huidige configuratie unencrypteduploaden (naar een webserver - moet wel PUT ondersteunen). Standaard wordt de configuratie nl. gecrypt (hoe en met welk wachtwoord: geen idee). En ja...in de configuratie staat bij de VOIP-instellingen de gebruikersnaam en het wachtwoord voor Ritstele. Echter, als ik dat wachtwoord invul, zowel in een ander modem als in de SX762, wordt dit niet door Rits geaccepteerd. Ik vermoed daarom dat het niet het volledige wachtwoord is.
En nee, ik ga dit wachtwoord niet vertellen omdat ik vermoed dat het gebruiker gebonden is.
Binnenkort zal ik meer informatie posten over hoe dat werkt met het uploaden van je configuratie via de CLI.
Welke commando gebruik je voor het uploaden?
Ik heb gebruikt:
upload config <web-server adres> u=<username> p=<password> noencrypt
maar ik krijg de volgende fout melding:
File transfer completed:
Response: Error, Upload failure
Geplaatst: 25 jun 2008, 00:54
door gr4vity
Op zich hou ik er niet zo van als dergelijke dingen hier op het forum verschijnen. Maar eigenlijk heeft dommel hier weinig aan te zeggen mits de router effectief jouw eigendom is. De enige manier waarop dommel dit kan verbieden is via het contract van homeconnect, maar ik heb geen idee of dit nu wel of niet een ander contract is.
Anyway, pas een beetje op met wat je hier verteld;)
Geplaatst: 25 jun 2008, 09:05
door meon
ey, L-army, d'er wordt hier eens wat tweakers-mentaliteit getoond en gij doet die mensen al schrik krijgen
Geplaatst: 25 jun 2008, 09:13
door gr4vity
hehe, ik ben gewoon voorzichtig
Geplaatst: 25 jun 2008, 09:17
door icekiller2k6
nja als we het niet meer hier mogen posten posten we het wel in het dommel topic @ tweakers
Geplaatst: 25 jun 2008, 09:20
door meon
icekiller2k6 schreef:nja als we het niet meer hier mogen posten posten we het wel in het dommel topic @ tweakers
neuh, plies post hier! plies plies!
Geplaatst: 25 jun 2008, 09:21
door gr4vity
Mijn excuses aan de tweaking people. Ik heb gewoon een beetje bang dat we het zelfde gaan voor krijgen als bij Tele2 een paar jaar terug
Geplaatst: 25 jun 2008, 09:23
door DimaX
L-army schreef:Mijn excuses aan de tweaking people. Ik heb gewoon een beetje bang dat we het zelfde gaan voor krijgen als bij Tele2 een paar jaar terug
En wat was er ?
Geplaatst: 25 jun 2008, 09:47
door ljd
Tele2 kwam dreigen met rechtzaken als het passwoord van hun routers niet van dit forum werd gehaald.
Geplaatst: 25 jun 2008, 18:31
door Ken
Er staat niets in het contract hierover en we belemmeren hiermee de werking alleszins niet van hun netwerk.
Alles van wachtwoorden en logins is default ingebakken in de Siemens.
Geplaatst: 25 jun 2008, 18:58
door deej
En waar vinden jullie toch al die info over SSH en toestanden?
Geplaatst: 25 jun 2008, 19:07
door icekiller2k6
dat is de truc...
Geplaatst: 26 jun 2008, 09:59
door icekiller2k6
@ken,
heb net hun siemens .dll doorlopen en vond per toeval (netdasm)
deze functie:
change_webmanagement_enabled
Geplaatst: 26 jun 2008, 18:52
door Ken
icekiller2k6 schreef:@ken,
deze functie:
Mja, die siemens dll wordt enkel maar gebruikt bij firmware updates enzo éh. Volgens mij moeten we zoeken in de siemens router zelf
Geplaatst: 27 jun 2008, 16:11
door FullHD
Kan er iemand nog via SSH aan zijn modem nadat die door Dommel correct geconfigureerd is? Ik geraak alleen nog op mijn modem via de web interface.
Geplaatst: 27 jun 2008, 16:25
door icekiller2k6
hmm meer info.. ^^ niet meer sshen? of is uw user & pass neit meer geldig?
Geplaatst: 27 jun 2008, 16:31
door FullHD
icekiller2k6 schreef:hmm meer info.. ^^ niet meer sshen? of is uw user & pass neit meer geldig?
Connection refused. Krijg zelfs niet eens de kans om user & pwd in te voeren.
Geplaatst: 27 jun 2008, 16:40
door icekiller2k6
doe is een portscan op uw router.. mss hebben ze port verandert.
