Kan ik naar een 6Mbit profiel gaan
Geplaatst: 26 maa 2008, 16:05
kan ik met deze waarden overstappen? anders steek ik er mijn tijd niet in:
Advanced DSL Port Configuration
Return to basic attribute list...
Advanced Port Attributes
Name Value
Driver Version 1.57
API Version GS_API_419
Firmware Version A.4.19.21
Dsp Version Turbo v1.0 A0 (0x40)
Connected true
Operational Mode G.Dmt
State Showtime
Watchdog 0x00000053
Operation Progress 0x000000ad
Last Failed 0x000000fd
Tx Bit Rate 384000
Rx Bit Rate 3328000
Tx Cell Rate 905
Rx Cell Rate 7849
Phy TX Cell Count 2666
Phy RX Cell Count 5997
Phy Cell Drop Count 0
Overall Failure 0
Local ITU Country Code 0x0000b5ff
Local SEF 0
Local End LOS 0
Local SNR Margin 25.5 dB
Local Line Attn 34.5 dB
Raw Attn 0.0 dB
Local Tx Power 11.9 dB
Local Fast Channel Rx Rate 3328000
Local Fast Channel Tx Rate 384000
Local Fast Channel FEC 0
Local Fast Channel CRC 2
Local Fast Channel HEC 0
Local Fast Channel NCD 0
Local Fast Channel OCD 0
Local Interleaved Channel Rx Rate 0
Local Interleaved Channel Tx Rate 0
Local Interleaved Channel FEC 0
Local Interleaved Channel CRC 0
Local Interleaved Channel HEC 0
Local Interleaved Channel NCD 0
Local Interleaved Channel OCD 0
Remote SEF 0
Remote LOS 0
Remote Line Attn 21.0 dB
Remote SNR Margin 24 dB
Remote Fast Channel FEC 0
Remote Fast Channel CRC 0
Remote Fast Channel HEC 0
Remote Fast Channel NCD 0
Remote Interleaved Channel FEC 0
Remote Interleaved Channel CRC 0
Remote Interleaved Channel HEC 0
Remote Interleaved Channel NCD 0
Host Control Enable
Auto Start True
Failsafe false
Whip Disable
Whip Active Inactive
Action Startup
Profile Main
Standard Multimode
Ec Fdm Mode FDM
Max Bits Per Bin 15
Tx Start Bin 6
Tx End Bin 31
Rx Start Bin 32
Rx End Bin 255
Rx Auto Bin Adjust Disable
Tx Attenuation 0
Bit Swap Enable
Bit Swap Up Disable
NTR Mode Enable
Annex Type AnnexA
Max Down Rate 131040000
Physical Port 0
Retrain Enable
Detect Noise Disable
Capability Disable
Coding Gain auto
Cut Back Disable
Framer Type Type3
Fast Retrain Disable
Dying Gasp Disable
Defaults None
Activate Line None
Reset Defaults False
Port Snmp If Index 1
Port Snmp If Type 37
Dank bij voorbaat
Name Value
Driver Version 1.57
Connected true
State Showtime
Watchdog 0x00000053
Tx Bit Rate 384000
Rx Bit Rate 3328000
Tx Cell Rate 905
Rx Cell Rate 7849
Overall Failure 0
Local SEF 0
Local End LOS 0
Raw Attn 0.0 dB
Remote SEF 0
Remote LOS 0
Host Control Enable
Auto Start True
Failsafe false
Whip Disable
Action Startup
Profile Main
Standard Multimode
Ec Fdm Mode FDM
Max Bits Per Bin 15
Tx Start Bin 6
Tx End Bin 31
Rx Start Bin 32
Rx End Bin 255
Tx Attenuation 0
Bit Swap Enable
Bit Swap Up Disable
NTR Mode Enable
Annex Type AnnexA
Physical Port 0
Retrain Enable
Capability Disable
Coding Gain auto
Cut Back Disable
Framer Type Type3
Dying Gasp Disable
Defaults None
Activate Line None
Dank bij voorbaat
