				EDPNET IS SLOW ....
				Geplaatst: 17 mei 2007, 11:21
				door nicdel
				Question, do you know why EDPNET is so slow since 2 days ?
No information on the EDPNET site....
I'm around 40k/s
Thanks.
				Geplaatst: 17 mei 2007, 11:23
				door Converted
				Where you from?
Same issue here. Position: Berchem (Antwerpen)
Around 100 K/s (instable)
Made already a ticket.
				Geplaatst: 17 mei 2007, 11:25
				door nicdel
				Kraainem (Brussels), when I check the latest speed test, I can see a lot of cities having the same issue....
				Geplaatst: 17 mei 2007, 11:28
				door Converted
				nicdel schreef:Kraainem (Brussels), when I check the latest speed test, I can see a lot of cities having the same issue....
 Wednesday May 16 2007
There is a general speed problem throughout French speaking Belgium and parts of the
Kempen and Flemish Brabant regions.
This problem will be solved as soon as possible.
We hope to have a solution by tomorrow.
We apologize for the inconveniences.
				Geplaatst: 17 mei 2007, 11:34
				door nicdel
				??? I don't see a special topic by following your link, only the homepage without any information on the issues...
Last results since 1 hour...
EDPnet	559	416	17/05/2007 11:16	EDPNET in KRAAINEM s**** since 3 days
EDPnet	4716	527	17/05/2007 11:14
EDPnet	4642	348	17/05/2007 11:14
EDPnet	227	527	17/05/2007 11:14	Mons very slow for 2 days
EDPnet	316	447	17/05/2007 11:13	EDPNET -> Kraainem
EDPnet	561	530	17/05/2007 11:11	EDPnet is slooooow in Auderghem
EDPnet	504	112	17/05/2007 11:09
EDPnet	511	530	17/05/2007 11:08	EDPnet is slooooow in Auderghem
EDPnet	482	523	17/05/2007 11:07	Home
EDPnet	609	530	17/05/2007 11:07	EDPnet in Auderghem
EDPnet	4764	527	17/05/2007 11:07
EDPnet	4711	527	17/05/2007 11:07
EDPnet	4840	530	17/05/2007 11:04
EDPnet	3461	402	17/05/2007 11:04	Visé
EDPnet	640	426	17/05/2007 11:03
EDPnet	4557	522	17/05/2007 11:02
EDPnet	4472	318	17/05/2007 11:02
EDPnet	611	423	17/05/2007 10:59	nivelles
EDPnet	1527	402	17/05/2007 10:53	Home
EDPnet	2134	320	17/05/2007 10:51
EDPnet	629	417	17/05/2007 10:29	MESSANCY
EDPnet	37	419	17/05/2007 10:25
				Geplaatst: 17 mei 2007, 11:39
				door Mr.T
				http://www.edpnet.be/cms.aspx?S=Helpcen ... tus_Issues
				Geplaatst: 17 mei 2007, 11:40
				door nicdel
				Thanks...
				Geplaatst: 17 mei 2007, 11:42
				door nicdel
				In fact it's from the 14/05....
Monday May 14 2007, 5:30 - 10:30 CET
A planned network maintenance to a main Broba II DSL router in Brussels has taken a
little longer than foreseen. This may have interrupted internet connections
throughout French speaking Belgium and parts of the Kempen and Flemish Brabant
regions.
In case you are still having trouble, it is best to reboot your modem/router.
What a quick service....i'm thinking to change provider....
				Hier even geplaatst
				Geplaatst: 17 mei 2007, 11:45
				door Converted
				Heeft hier iemand dezelfde problemen rond (instabiele) snelheid? Enorm slechte downloadsnelheden de afgelopen 3 dagen.
Al alles geprobeerd: andere modems (beide Thomson ST 536 v6), reset, restart, splitters nagekeken, kabels nagekeken.
Zou echt niet weten wat er nog meer zou kunnen zijn.
Zit in de regio Berchem-Antwerpen.
Iemand die in hetzelfde schuitje zit?
Modemlogs zien er goed uit voor een stabiele verbinding (6Mbit/s):
				Geplaatst: 17 mei 2007, 11:46
				door Mr.T
				The speed problem has nothing to do with the outage of the Broba II DSL router. That outage was caused by a planned maintenance (software upgrade) which went wrong.
				Geplaatst: 17 mei 2007, 11:48
				door nicdel
				Ok but it's the same part of belgium affected...and since the same moment we have speed issue...
But perhaps is it not linked....
				Geplaatst: 17 mei 2007, 17:36
				door airzimmy
				We're just temporarily rerouting all edpnet traffic over the userbase.be server, that's why others are complaining this server is slow too!
JOKE!
				Geplaatst: 17 mei 2007, 17:37
				door meon
				That seems like a plausible reason to me too
				Geplaatst: 18 mei 2007, 20:18
				door jve
				Voor zij die het zich nog moesten afvragen, hier is de snelheid van EDPnet ondertussen terug in orde (vanaf 14u vandaag).
