mysql import probleem.
Geplaatst: 17 mei 2006, 19:45
door crapiecorn
Na wisselen van os wou ik alle sql files terug importeren maar deze gaven een rare fout.
dump file
-- MySQL dump 10.9
-- Host: localhost    Database: crapiecorn
-- Server version	4.1.16
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
/*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
/*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
/*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
/*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
-- Table structure for table `film`
DROP TABLE IF EXISTS `film`;
CREATE TABLE `film` (
  `id` int(11) NOT NULL auto_increment,
  `filmnaam` varchar(50) NOT NULL default '',
  `date` varchar(50) NOT NULL default '',
  `duur` varchar(50) NOT NULL default '',
  `type` varchar(50) NOT NULL default '',
  `extra` text NOT NULL,
  PRIMARY KEY  (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
-- Dumping data for table `film`
/*!40000 ALTER TABLE `film` DISABLE KEYS */;
LOCK TABLES `film` WRITE;
INSERT INTO `film` VALUES (1,'Akira','03-03-2006 03:16:32','02:00:01','MPEG2','OUwwww Ahhhhh');
UNLOCK TABLES;
/*!40000 ALTER TABLE `film` ENABLE KEYS */;
/*!40101 SET SQL_MODE=@OLD_SQL_MODE */;
/*!40014 SET FOREIGN_KEY_CHECKS=@OLD_FOREIGN_KEY_CHECKS */;
/*!40014 SET UNIQUE_CHECKS=@OLD_UNIQUE_CHECKS */;
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
/*!40111 SET SQL_NOTES=@OLD_SQL_NOTES */;
fout :
Fout
SQL-query:
-- MySQL dump 10.9
MySQL retourneerde: Documentatie
#1065 - Query was empty
probleem ligt waarschijnlijk bij character set. Maar deze komt overeen met met de vorige als ik me niet vergis.
Geplaatst: 17 mei 2006, 20:41
door meon
doe eens een 'select version()' op je nieuwe server?
Geplaatst: 18 mei 2006, 05:41
door crapiecorn
Deze heeft een iets oudere versie geinstalled 4.0.24.
