x users online simpel !!!!
Geplaatst: 24 jun 2003, 03:58
hallo,
op vele websites zie je dit tegenwoordig.Ik bedoel het aantal gebruikers dat op de site zit. hoe doen die da ? simpel
dan moet je een MySQL database table maken
in elk bestand dat je nu de aantal gebruikers wilt tonen dat online is op de site voeg je dit bestand in eg
voila ....
<?php
$server="localhost";
$db_user="mysql_user";
$db_pass="mysql_pass";
$db="databasename";
$ip=$_SERVER['REMOTE_ADDR'];
$timeoutseconds=300;
$timestamp = time();
$timeout=$timestamp-$timeoutseconds;
mysql_connect($server,$db_user,$db_pass) or die (mysql_error());
mysql_select_db($db);
$insert=mysql_query("INSERT INTO useronline VALUES ('$timestamp','$ip','$PHP_SELF')");
if(!$insert){
die("useronline insert failed");
$delete=mysql_query("DELETE FROM useronline WHERE timestamp<$timeout");
if(!$delete){
die("could not delete information from the database");
$result=mysql_query("SELECT DISTINCT ip FROM useronline WHERE file='$PHP_SELF'");
if(!$result){
die("database selection error");
$user=mysql_num_rows($result);
mysql_close();
if($user ==1) {
print("<b>$user</b>user online\n");
}else{
print("<b>$user</b> users online\n");
CREATE TABLE useronline (
timestamp int(15) DEFAULT '0' NOT NULL,
ip varchar(40) NOT NULL,
file varchar(100) NOT NULL,
PRIMARY KEY (timestamp),
KEY ip (ip),
KEY file (file)
<?php include("filename.php") ?>
