Re: Monitor je energieverbruik met 1 toestel, smappee monito
Geplaatst: 28 dec 2013, 12:05
Heel interessante topic op zonnestraal. Toont een iets minder positieve zijde van het apparaat. Waarschijnlijk realistischer?
Users United
https://test-goztow.userbase.be/forum/
Post made via mobile device ]Code: Selecteer alles
Instantaneous second values
Instantaneous values:
voltage=235.7 Vrms
FFTComponents:
FFTComponent index=51, magnitude=332.887 V max, phase=339.588, frequency=49.804 Hz
FFTComponent index=154, magnitude=1.53 V max, phase=22.187, frequency=150.39 Hz
FFTComponent index=256, magnitude=0.56 V max, phase=237.656, frequency=250.0 Hz
FFTComponent index=358, magnitude=2.082 V max, phase=232.612, frequency=349.609 Hz
FFTComponent index=461, magnitude=0.621 V max, phase=39.692, frequency=450.195 Hz
Phase 1:
current=0.824 A, activePower=171.399 W, reactivePower=91.754 var, apparentPower=194.413 VA, cosfi=87, quadrant=4, phaseshift=-10.942, phaseDiff=349.057
FFTComponents:
FFTComponent index=51, magnitude=1.039 A max, phase=350.531, frequency=49.804 Hz
FFTComponent index=102, magnitude=0.023 A max, phase=198.606, frequency=99.609 Hz
FFTComponent index=154, magnitude=0.413 A max, phase=172.621, frequency=150.39 Hz
FFTComponent index=256, magnitude=0.071 A max, phase=175.631, frequency=250.0 Hz
FFTComponent index=358, magnitude=0.137 A max, phase=263.349, frequency=349.609 Hz
FFTComponent index=461, magnitude=0.179 A max, phase=93.902, frequency=450.195 Hz
FFTComponent index=563, magnitude=0.111 A max, phase=91.092, frequency=549.804 Hz
FFTComponent index=666, magnitude=0.04 A max, phase=300.233, frequency=650.39 Hz
FFTComponent index=768, magnitude=0.047 A max, phase=5.117, frequency=750.0 Hz
FFTComponent index=870, magnitude=0.04 A max, phase=24.217, frequency=849.609 Hz
FFTComponent index=973, magnitude=0.011 A max, phase=238.641, frequency=950.195 Hz
FFTComponent index=1075, magnitude=0.01 A max, phase=272.842, frequency=1049.804 Hz
Phase 2:
current=0.969 A, activePower=181.233 W, reactivePower=139.396 var, apparentPower=228.641 VA, cosfi=79, quadrant=4, phaseshift=-7.508, phaseDiff=352.491
FFTComponents:
FFTComponent index=1, magnitude=0.024 A max, phase=184.284, frequency=0.976 Hz
FFTComponent index=51, magnitude=1.097 A max, phase=227.096, frequency=49.804 Hz
FFTComponent index=154, magnitude=0.549 A max, phase=136.68, frequency=150.39 Hz
FFTComponent index=256, magnitude=0.42 A max, phase=215.165, frequency=250.0 Hz
FFTComponent index=358, magnitude=0.286 A max, phase=302.64, frequency=349.609 Hz
FFTComponent index=461, magnitude=0.169 A max, phase=220.517, frequency=450.195 Hz
FFTComponent index=563, magnitude=0.073 A max, phase=336.52, frequency=549.804 Hz
FFTComponent index=666, magnitude=0.061 A max, phase=308.882, frequency=650.39 Hz
FFTComponent index=768, magnitude=0.085 A max, phase=62.705, frequency=750.0 Hz
FFTComponent index=870, magnitude=0.104 A max, phase=159.649, frequency=849.609 Hz
FFTComponent index=973, magnitude=0.076 A max, phase=77.901, frequency=950.195 Hz
FFTComponent index=1075, magnitude=0.057 A max, phase=177.671, frequency=1049.804 Hz
FFTComponent index=1178, magnitude=0.03 A max, phase=112.238, frequency=1150.39 Hz
FFTComponent index=1280, magnitude=0.015 A max, phase=229.649, frequency=1250.0 Hz
FFTComponent index=1382, magnitude=0.024 A max, phase=338.153, frequency=1349.609 Hz
FFTComponent index=1485, magnitude=0.012 A max, phase=261.861, frequency=1450.195 Hz
Phase 3:
current=4.274 A, activePower=933.777 W, reactivePower=379.095 var, apparentPower=1007.796 VA, cosfi=92, quadrant=1, phaseshift=3.693, phaseDiff=3.693
FFTComponents:
FFTComponent index=1, magnitude=0.024 A max, phase=7.628, frequency=0.976 Hz
FFTComponent index=51, magnitude=5.656 A max, phase=95.894, frequency=49.804 Hz
FFTComponent index=102, magnitude=0.025 A max, phase=217.396, frequency=99.609 Hz
FFTComponent index=154, magnitude=1.709 A max, phase=142.352, frequency=150.39 Hz
FFTComponent index=256, magnitude=0.906 A max, phase=301.583, frequency=250.0 Hz
FFTComponent index=358, magnitude=0.633 A max, phase=115.442, frequency=349.609 Hz
FFTComponent index=461, magnitude=0.592 A max, phase=121.908, frequency=450.195 Hz
FFTComponent index=563, magnitude=0.364 A max, phase=326.215, frequency=549.804 Hz
FFTComponent index=666, magnitude=0.129 A max, phase=22.517, frequency=650.39 Hz
FFTComponent index=768, magnitude=0.081 A max, phase=347.195, frequency=750.0 Hz
FFTComponent index=870, magnitude=0.133 A max, phase=205.441, frequency=849.609 Hz
FFTComponent index=973, magnitude=0.059 A max, phase=217.566, frequency=950.195 Hz
FFTComponent index=1075, magnitude=0.026 A max, phase=335.162, frequency=1049.804 Hz
FFTComponent index=1178, magnitude=0.031 A max, phase=345.097, frequency=1150.39 Hz
FFTComponent index=1485, magnitude=0.012 A max, phase=234.951, frequency=1450.195 Hz
Post made via mobile device ]Wat bedoel je hier eigenlijk mee Goztow ?Goztow schreef:...
Zelf heb ik al een android maar heb geen stopcontact dichtbij de elektriciteitskas, die in de trappenhal staat...
Deze waardes heb ik zelf uitgelezen uit mijn smappee ...lacer schreef:@Jaker: Na je edit > dat zou leuk zijn moest je die waarden effectief allemaal zelf kunnen uitlezen
Post made via mobile device ]Voorlopig nog niet. Dat was trouwens ook een vraag van mij aan smappee support:trikke2705 schreef:Kan je via de app ook zien hoeveel ieder toestel verbruikt op maand- en/of jaarbasis?
Beste,
Bedankt voor uw vraag.
Wij horen van veel klanten de wens voor rapporten. Momenteel is dat nog niet mogelijk, maar wij werken er aan.
Met vriendelijke groten,
smappee
Jan007 schreef:Een stopcontact op DIN-rail bijplaatsen in een zekeringenkast kan makkelijk als er nog plaats vrij is.
Goztow schreef:Ik woon in een appartement. De hoofdelektriciteitskast staat in de trappenhal. Toegankelijk voor eender wie van het gebouw. Er is weinig plaats want die van mijn buur staat er vlak naast.
Post made via mobile device ]De app die gebruikt wordt in Sint Niklaas voor gasmonitoring is gelijkaardig aan energieID: je kan er een actieve meter aan koppelen (van externe partijen), maar ook gewoon maandelijks de meterstand manueel aflezen: http://onnergy.com/nl/Voorlopig blijf ik nog bij http://www.energieID.be
Nadeel is dat ik minstens 1 maal in de maand mijn meters moet gaan bekijken
