Re: freepbx + weepee
Geplaatst: 25 nov 2012, 12:04
Denk niet dat er daar iets zal instaan. Kom steevast op voicemail terecht bij weepee.
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:1] Set("SIP/weepee-0000004d", "__FROM_DID=323369xxxx") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:2] Gosub("SIP/weepee-0000004d", "app-blacklist-check,s,1()") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:1] GotoIf("SIP/weepee-0000004d", "0?blacklisted") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:2] Set("SIP/weepee-0000004d", "CALLED_BLACKLIST=1") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:3] Return("SIP/weepee-0000004d", "") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:3] Set("SIP/weepee-0000004d", "CDR(did)=323369xxxx") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:4] ExecIf("SIP/weepee-0000004d", "0 ?Set(CALLERID(name)=049xxxxxxx)") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:5] Set("SIP/weepee-0000004d", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:6] Set("SIP/weepee-0000004d", "CALLERPRES()=allowed_not_screened") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:7] Goto("SIP/weepee-0000004d", "from-did-direct,xxxx,1") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Goto (from-did-direct,xxxx,1)
Hieronder hoe ik het heb naar een softphone. Voip telefoon is onderweg.fryelectro schreef:Ter info, dit is hoe bij mij een gesprek binnenkomt, bemerk de DID notatie. Hiervoor bestaat een inbound route naar een interne extensie.
[2012-11-27 15:50:33] VERBOSE[2718] netsock2.c: == Using SIP RTP TOS bits 184
[2012-11-27 15:50:33] VERBOSE[2718] netsock2.c: == Using SIP RTP CoS mark 5
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:1] ResetCDR("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:2] NoCDR("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:3] Progress("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:4] Wait("SIP/100-0000001a", "1") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:5] Progress("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:6] Playback("SIP/100-0000001a", "silence/1&cannot-complete-as-dialed&check-number-dial-again,noanswer") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] file.c: -- <SIP/100-0000001a> Playing 'silence/1.ulaw' (language 'en')
[2012-11-27 15:50:35] VERBOSE[30743] file.c: -- <SIP/100-0000001a> Playing 'cannot-complete-as-dialed.ulaw' (language 'en')
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: == Spawn extension (from-internal, 32472xxxxxxx, 6) exited non-zero on 'SIP/100-0000001a'
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/100-0000001a'
Pardon ? Waarom zou een gewone SIP account niet werken met FreePBX ?weepeechris schreef:Voor FreePBX zal je een Sip Trunk account nodig hebben, een gewone SIP account of FWD account zal niet werken.
Zorg er eerst voor dat alle nummers en accounts die je op heden bij WeePee hebt toekomen op je trunk account. Dan kan je beginnen spelen met je PBX en gaat een wondere wereld open voor jedevastator schreef:Heb een trunk aangemaakt.
Moet ik dan in de forward account het nr van deze account ook vermelden ?
Chris, helemaal niet. Ik heb hier mischien wel 10 accounts op een FreePBX gekoppeld dewelke géén trunk accounts zijn. Trunk is enkel nodig indien je meerdere nummers via 1 registratie wil. Als je slechts 1 nummer hebt kan je beter een gewone account nemen.weepeechris schreef:@VoID PBX = trunk nodig
username=32990900xxxx
type=friend
trustrpid=yes
sendrpid=yes
secret=*password*
qualify=yes
insecure=port,invite
host=sswX.brussels.weepee.org
fromuser=32990900xxxx
fromdomain=sswX.brussels.weepee.org
disallow=all
canreinvite=yes
allow=alaw
32990900xxxx:*password*@sswX.brussels.weepee.org/*telefoonnummer*
32990900XXXX:[email protected]/011abcdef
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [dstring@macro-dial-one:12] Set("SIP/WeePee-00000000", "DSTRING=SIP/0") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [dstring@macro-dial-one:13] Return("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:27] GotoIf("SIP/WeePee-00000000", "0?nodial") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:28] GotoIf("SIP/WeePee-00000000", "0?skiptrace") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:29] GosubIf("SIP/WeePee-00000000", "1?ctset,1():ctclear,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [ctset@macro-dial-one:1] Set("SIP/WeePee-00000000", "DB(CALLTRACE/0)=0497<SNIP>") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [ctset@macro-dial-one:2] Return("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:30] Set("SIP/WeePee-00000000", "D_OPTIONS=tr") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:31] ExecIf("SIP/WeePee-00000000", "0?SIPAddHeader(Alert-Info: )") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:32] ExecIf("SIP/WeePee-00000000", "0?SIPAddHeader()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:33] ExecIf("SIP/WeePee-00000000", "0?Set(CHANNEL(musicclass)=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:34] GosubIf("SIP/WeePee-00000000", "0?qwait,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:35] Set("SIP/WeePee-00000000", "__CWIGNORE=") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:36] Set("SIP/WeePee-00000000", "__KEEPCID=TRUE") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:37] GotoIf("SIP/WeePee-00000000", "0?usegoto,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:38] GotoIf("SIP/WeePee-00000000", "1?godial") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-dial-one,s,42)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:42] Dial("SIP/WeePee-00000000", "SIP/0,,tr") in new stack
[2013-04-03 18:39:48] WARNING[2408] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2013-04-03 18:39:48] VERBOSE[2408] app_dial.c: == Everyone is busy/congested at this time (1:0/0/1)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:43] ExecIf("SIP/WeePee-00000000", "0?Set(DIALSTATUS=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:44] GosubIf("SIP/WeePee-00000000", "0?s-CHANUNAVAIL,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:45] MacroExit("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:15] Set("SIP/WeePee-00000000", "SV_DIALSTATUS=CHANUNAVAIL") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:16] GosubIf("SIP/WeePee-00000000", "0?docfu,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:17] GosubIf("SIP/WeePee-00000000", "0?docfb,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:18] Set("SIP/WeePee-00000000", "DIALSTATUS=CHANUNAVAIL") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:19] ExecIf("SIP/WeePee-00000000", "0?MacroExit()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:20] GotoIf("SIP/WeePee-00000000", "1?s-CHANUNAVAIL,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-exten-vm,s-CHANUNAVAIL,1)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:1] GotoIf("SIP/WeePee-00000000", "0?exit,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:2] PlayTones("SIP/WeePee-00000000", "congestion") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:3] Congestion("SIP/WeePee-00000000", "10") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] app_macro.c: == Spawn extension (macro-exten-vm, s-CHANUNAVAIL, 3) exited non-zero on 'SIP/WeePee-00000000' in macro 'exten-vm'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: == Spawn extension (from-did-direct, 0, 2) exited non-zero on 'SIP/WeePee-00000000'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [h@from-did-direct:1] Macro("SIP/WeePee-00000000", "hangupcall,") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/WeePee-00000000", "1?theend") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-hangupcall,s,3)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:3] ExecIf("SIP/WeePee-00000000", "0?Set(CDR(recordingfile)=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:4] Hangup("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] app_macro.c: == Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/WeePee-00000000' in macro 'hangupcall'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: == Spawn extension (from-did-direct, h, 1) exited non-zero on 'SIP/WeePee-00000000'
[2013-04-03 21:38:33] NOTICE[1528] chan_sip.c: Call from '0' (192.168.0.16:40100) to extension '+32497<SNIP>' rejected because extension not found in context 'from-internal'.
047.
