bearshare
under Control
hallo,een vraagje,wat kan ik nog doen als er geen verbinding gemaakt word met de bearshare hosts?? surfen in de bearshare lukt vanzelf ,maar iets opzoeken,dus zoekopdracht ingeven en enteren,maakt geen connectie,ook niet met de firewall af! Wat kan er nog gedaan worden ?? Heb firewall afgezet ,de norton ook,de poort nummers veranderd ,doch geen connectie met de host(zegt tem zelf).
Have mutch fun with your pc --Thats all folks!!
MaRtO
Q: When I search, why do I not get any results?
A: If the status for your search reads "Queued - Connections stabilizing - Please wait" then you are not connected to the network. If this continues for some time then please consult our Troubleshooting Guide. Make sure you have spelled your search correctly and the Type is what you intended. Enabling the Family Filter or Visual Filter (on the Options page of Setup) will reduce the number of results available to you as will too many filtered extensions (on the Searching page of Setup). BearShare will stop searching after a certain number of results are found so what you are looking for may get 'drowned out' by other search results. If you have set some advanced search options such as file sizes then BearShare may be receiving lots of results but not showing them because of the advanced limits.
Altijd eerst de FaQ lezen ;)
Lukse
Lees dit ook maar eens: http://tweakers.net/nieuws/39082
Terug naar “Software en apps”
