Hi,
ik heb netconnect van Dommel. Nu is het heel vaak zo dat mijn lijn eruit valt en dat het dan heel lang duurt eer ik weer online ben
mijn gegevens van de modem:
line att 46.3
crc 323
log:
9/15/2010 11:16:21> ADSL detected
9/15/2010 11:16:28> ATM Connected
9/15/2010 11:16:28> ATM layer is up, cell delineation achieved
9/15/2010 11:16:28> ADSL connected
9/15/2010 11:16:32> PPP1 PPPoE Session is established.
9/15/2010 11:16:33> PPP CHAP Authentication success
9/15/2010 11:16:33> PPP1: PPP IP address is xx.xx.xx.xx
9/15/2010 11:16:33> PPP1: PPP Gateway IP address is xx.xx.xx.xx
9/15/2010 11:16:33> PPP1: DNS Primary IP address is xx.xx.xx.xx
9/15/2010 11:16:33> PPP1: DNS Secondary IP address is xx.xx.xx.xx
9/15/2010 11:16:33> NAT/NAPT Session Start: interface ppp1, WAN IP is xx.xx.xx.xx
9/15/2010 11:16:33> Initialized NAT Virtual Servers.
9/15/2010 11:16:33> No Static Session Information is defined.
9/15/2010 11:16:33> PPP1 Session is up.
9/15/2010 11:16:33> ATM Disconnected
9/15/2010 11:16:33> ADSL disconnected
9/15/2010 11:16:36> PPP1 Session is down.
9/15/2010 11:16:36> NAT/NAPT Session Stop: interface ppp1
9/15/2010 11:17:10> ADSL detected
9/15/2010 11:17:16> ATM Connected
9/15/2010 11:17:16> ATM layer is up, cell delineation achieved
9/15/2010 11:17:16> ADSL connected
9/15/2010 11:17:20> PPP1 PPPoE Session is established.
9/15/2010 11:17:21> ATM Disconnected
9/15/2010 11:17:21> ADSL disconnected
9/15/2010 11:17:23> PPP1 Session is down.
9/15/2010 11:17:44> ADSL detected
9/15/2010 11:17:51> ATM Connected
9/15/2010 11:17:51> ATM layer is up, cell delineation achieved
9/15/2010 11:17:51> ADSL connected
9/15/2010 11:17:55> PPP1 PPPoE Session is established.
9/15/2010 11:17:55> PPP CHAP Authentication success
9/15/2010 11:17:56> PPP1: PPP IP address is xx.xx.xx.xx
9/15/2010 11:17:56> PPP1: PPP Gateway IP address is xx.xx.xx.xx
9/15/2010 11:17:56> PPP1: DNS Primary IP address is xx.xx.xx.xx
9/15/2010 11:17:56> PPP1: DNS Secondary IP address is xx.xx.xx.xx
9/15/2010 11:17:56> NAT/NAPT Session Start: interface ppp1, WAN IP is xx.xx.xx.xx
9/15/2010 11:17:56> Initialized NAT Virtual Servers.
9/15/2010 11:17:56> No Static Session Information is defined.
9/15/2010 11:17:56> PPP1 Session is up.
9/15/2010 11:17:56> Regained contact with DNS servers
9/15/2010 11:17:56> ATM Disconnected
9/15/2010 11:17:56> ADSL disconnected
9/15/2010 11:17:59> PPP1 Session is down.
9/15/2010 11:17:59> NAT/NAPT Session Stop: interface ppp1
ik weet dat ik ver van de centrale zit, maar nu krijg ik elke dag om 12.00 uur een downtime van tussen de 1 minuut en 1 uur..
iemand een idee wat dit zou kunnen zijn? filter is al vervangen (adsl blokje waar de lijn binnenkomt)
Heb zowieso maar eens VDLS besteld, maar ben toch wel geinteresserd in waarom dit zo slecht loopt..
thx!
YggY
probleem met inbellen
- honda4life
- Bedankt: 391 keer
Ik zie dat je de line attenuation gevonden hebt, dit is inderdaad ver van de centrale (of een fout in de bekabeling)
Kan je de SNR waarden eens niet opzoeken, de SYNC enzo.
Zie ook de tutorials "hoe test ik mijn lijn zelf"
de SNR Margin is 9.1 downstream en 27.0 upstream (zegt mij helemaal niets
errored seconds is ook leuk : 56038..
starup attempts: 78..
iets is er grondig mis..
zou dit blijven ook als ik overga naar VDSL? met andere woorden zou er iets aan de kabel zijn?
Modem zit rechstreeks aan eerste punt waar kabel huis binnen komt overigens..
- honda4life
- Bedankt: 391 keer
Je hebt veel storing op de lijn, toch zou dit nog niet probematisch mogen zijn.
- Bedankt: 3720 keer
* Als er iets "grondigs mis" is met je telefooonlijn, dan zou je ook wel eens problemen kunnen krijgen op VDSL2.yggy schreef:iets is er grondig mis..
* Zijn er nog andere aftakkingen na het eerste punt waar de kabel binnenkomt? Indien JA, koppel deze eens volledig af, en kijk eens of er verbetering is.
* Indien je deze aftakkingen nog nodig hebt wegens telefoon, dan moet je:
- toch eens verder kijken of je overal telefoon nodig hebt waar er nog aftakkingen zijn, zoniet overbodige aftakkingen elimineren.
- maak dat je overal splitters hebt, waar er nog telefoon is.
- Of idealiter, plaats een full-rate splitter op het eerste punt, en gebruik de telefoon-uitgang van de splitter voor alle verdere aftakkingen.
Philippe.
hi,
Nee, er zit niets verder op die lijn, alleen zon ADSL splitter met een normale telefoon aansluiting er achter op.. (maakt niet uit of ik telefoon eruit trek of niet)
hmm anders toch maar eens een Belgacom menneke laten af komen.. hmm
