Probleempje:
Fraps is een heel goei programma om bv ingame filmpjes te maken.
Enkel 1 groot nadeel: t'is raw en dus al snel heeeeel groot..
2 minuten kan al snel 3-4gb zijn..
Mijn vraag is: hoe kan je een ingame filmke maken dat niet te groot is (bv 30 - 50mb) met toch nog een behoorlijk goeie kwaliteit?
Fraps en uploaden
- meon
- Twitter: meon
- Bedankt: 780 keer
Fraps.
En achteraf hercoderen.
Dat het RAW is is maar goed ook, anders zou je behoorlijk wat performance kwijt zijn aan het realtime compressie-algoritme, en zou de kwaliteit inferieur zijn omdat het single-pass is.
- Dafke
- Bedankt: 157 keer
Why is the AVI movie generated by Fraps so big? How can I reduce the size?
The filesize is big because there isn’t enough time to encode the movie while the game is running. The movie frames are slightly compressed, but still require a large amount of disk space due to the high resolutions. Once you have finished capturing you should convert the saved AVI into one of the popular compressed movie formats such as mpeg or divx. Recommended programs for doing this are tmpgenc (Tsunami Mpeg Encoder), and VirtualDub.
Using VirtualDub is quite easy. To create a compressed version of the AVI follow these steps:
Start VirtualDub
Select File->Open and choose the AVI in the Fraps directory you wish to compress.
Select Video->Compression and choose the codec you wish to compress with (usually divx)
Select File->Save As AVI and specify a filename for the new AVI.
If you have Windows XP you can also use Windows Movie Maker to compress the video files. If you use Windows Movie Maker it's recommended that you keep your Fraps video files at 800x600 or under.
Why do I get a source format error when I try to compress with DIVX?
Divx6 places restrictions on the video resolution for many of its profiles and this may cause an error when handling large Fraps videos. In Virtualdub you can go to the Divx codec configuration screen and set it to use the "Unconstrained Profile". This will allow you to encode movies of any resolution and won't generate the source format error.
vwalla zelf gevonden op de site
en meon, eigenlijk mijn vraag was onrechtstreeks: hoe converteren/comprimeren
Start VirtualDub
