Daar kunt ge verdorie op koken!ZMD schreef:Pff, mijn cores worden 74°C!!!!! (Ook een T7200)
lol
Currently we have dedicated win SMP work units. Three projects are being assigned at this time:
Project 2610: 1523 points, deadline 4 days bij mij 40m/%
Project 2651: 1760 points, deadline 4 days bij mij 31m/%, andere wu 30'/%
Project 2652: 1148 points, deadline 3 days bij mij 27m/%
[19:37:52] - Writing 5499768 bytes of core data to disk...
[19:37:52] ... Done.
[19:37:52] - Failed to delete work/wudata_01.sas
[19:37:52] - Failed to delete work/wudata_01.goe
[19:37:52] Warning: check for stray files
Ik heb hier tans een yonah T2400 naast me draaien, deze komt in rust nauwelijks boven de 35°C. De architectuur is toch niet zo verschillendNuKeM schreef:Mijn CPU doet nu NIETS en is 70°C![]()
Dat volgens Notebook Hardware Control...
Even F@H opzetten en kijken wat dat gaat worden
Add: Het is blijkbaar de software http://forum.notebookreview.com/showthr ... emperature
Add2: Of toch nietAndere software die volgens het forum wel juist moet zijn op mijn laptop zegt ook 79-80°C voor elke core
[17:53:10] Folding@Home Gromacs SMP Core
[17:53:10] Version 1.74 (March 10, 2007)
[17:53:10]
[17:53:10] Preparing to commence simulation
[17:53:10] - Ensuring status. Please wait.
[17:53:17] - Starting from initial work packet
[17:53:20]
[17:53:20] Project: 2610 (Run 0, Clone 995, Gen 0)
[17:53:20]
[17:53:20] Assembly optimizations on if available.
[17:53:20] Entering M.D.
[17:53:34] 6 percent)
[17:53:34] cket
[17:53:34]
[17:53:34] Project: 2610 (Run 0, Clone 995, Gen 0)
[17:53:34]
[17:53:34] 610 (Run 0, Clone 995, Gen 0)
[17:53:34]
[17:53:34] Entering M.D.
[17:53:40] Rejecting checkpoint
[17:53:42] Protein: Protein
[17:53:42] Writing local files
[17:53:43] Extra SSE boost OK.
[17:53:43] Writing local files
[17:53:43] Completed 0 out of 500000 steps (0 percent)
[18:08:17] Writing local files
[18:08:18] Completed 5000 out of 500000 steps (1 percent)
[18:23:21] Writing local files
[18:23:21] Completed 10000 out of 500000 steps (2 percent)
OS is XP met SP2.Sven.VdS schreef:Bossie: met welk OS is dat? 15min is echt wel snel ... zelfs afgezien van het feit dat er binnen een project nog verschillen zitten in de WU's qua moeilijkheid om te berekenen ...
kudo's
Zijn er op dit ogenblik wel cores zonder deadline voorhanden ? Voor zover ik weet nl. niet.Bossie schreef:Daarmee had ik bij advanced options WU's genomen zonder deadline. Maar dan kan hij geen nieuwe core downloaden.
Hier nog niet voorbij zien komen, ik zie menteel alleen 2610' sSven.VdS schreef:Ter update:
een 2605 WU doet er op m'n T7200 22m/% over.
Hier 38-42 minuten.Sven.VdS schreef:De vorige 2610 op m'n P4 D930 had maar 25m/% nodig ... degene die nu aan het lopen is heeft er 31m voor nodig ... van WU tot WU (binnen hetzelfde project) kunnen er zich precies nog aanzienlijke verschillen voordoen.
[16:00:17] Writing local files
[16:00:17] Extra SSE boost OK.
[16:00:17] Completed 0 out of 5000000 steps (0)
[16:13:18] Writing local files
[16:13:18] Completed 50000 out of 5000000 steps (1)
Idem hier, al die verschillende clients, cores & opties beginnen serieus verwarrend te worden. Ze zouden eens een chart moeten maken wie nu wat juist moet draaien.Sven.VdS schreef:80+ dagen lijkt mij voor eender welke WU onrealistisch .. en zeker voor zo'n CPU.
Ok vals alarm... na een aantal frames complete is de "WU End" een stuk accurater... 1 dag ipv 80 dagen... Is dit hetzelfde bij jou Nob?Sven.VdS schreef:80+ dagen lijkt mij voor eender welke WU onrealistisch .. en zeker voor zo'n CPU.
Ja das compleet normaal hoor.Styno schreef:Ok vals alarm... na een aantal frames complete is de "WU End" een stuk accurater... 1 dag ipv 80 dagen... Is dit hetzelfde bij jou Nob?Sven.VdS schreef:80+ dagen lijkt mij voor eender welke WU onrealistisch .. en zeker voor zo'n CPU.
Een HyperThreading gaat altijd maar naar 50% ... is hier ook zo. Je KAN er de SMP client op draaien maar zoals ik eerder al eens postte krijg je die WU's nooit (of amper) op tijd klaar.Styno schreef:Idem hier, al die verschillende clients, cores & opties beginnen serieus verwarrend te worden. Ze zouden eens een chart moeten maken wie nu wat juist moet draaien.Sven.VdS schreef:80+ dagen lijkt mij voor eender welke WU onrealistisch .. en zeker voor zo'n CPU.
Volgende shot is een testrun met de default settings op een grafishe client. De cpu gaat naar 50% (ht)
Inderdaad, blijkbaar doet hij er even over om de juiste tijd te berekenen.Is dit hetzelfde bij jou Nob?
Idd... ge zit verdorie aan een gemiddelde van 2500 ppd.. stop daar eens mee, hoe kunnen wij u nu ooit nog bijbenenLimburg schreef:Zeg Sven,
heb je die 2 notebooks nog niet aan die klant meegegeven?
[15:31:55] Completed 465000 out of 500000 steps (93 percent)
[16:24:24] Writing local files
[16:24:24] Completed 470000 out of 500000 steps (94 percent)
[17:18:23] Writing local files
[17:18:23] Completed 475000 out of 500000 steps (95 percent)
[18:13:14] Writing local files
[18:13:15] Completed 480000 out of 500000 steps (96 percent)
[19:08:56] Writing local files
[19:08:56] Completed 485000 out of 500000 steps (97 percent)
[20:08:42] Writing local files
[20:08:42] Completed 490000 out of 500000 steps (98 percent)
[20:55:56] CoreStatus = 1 (1)
[20:55:56] Client-core communications error: ERROR 0x1
[20:55:56] Deleting current work unit & continuing...
[20:56:05] - Preparing to get new work unit...
Jawel hoor die hebben maar 3 dagen gedraaid in dat verlengd weekend onlangs ... de 24h average is ondertussen weer een pak gedaaldLimburg schreef:Zeg Sven,
Heb je al enig inzicht hoe vista vs xp draait op gelijke machines en wu's?
Door een dual quadcore xeon te kopen ... maar wie zou DAT nu in godsnaam ooit doenStyno schreef:Idd... ge zit verdorie aan een gemiddelde van 2500 ppd.. stop daar eens mee, hoe kunnen wij u nu ooit nog bijbenenLimburg schreef:Zeg Sven,
beter dan gewoon ps3 of ati gpu's in crossfireSven.VdS schreef:Door een dual quadcore xeon te kopen ... maar wie zou DAT nu in godsnaam ooit doenStyno schreef:Idd... ge zit verdorie aan een gemiddelde van 2500 ppd.. stop daar eens mee, hoe kunnen wij u nu ooit nog bijbenenLimburg schreef:Zeg Sven,
PS: ZMD, innige medeleving
